Problem while pc shutdown and startup
While i was shutting down my desktop computer,it took more than 15 min and when i started my pc again with out loading os ,my desktop screen (with out any icons) apeared. I restarted immediately and its working somewhat slow.
what might be the problem ? is the problem related to?
  • Ludwe Matanzima Mar 17, 2008
    I have just bought an HP Pavion dv6000 with Windows Vista two days ago. On the first day things were fine but from the second day it took about 10 minutes to startup and its also doing the same thing when I am shuting it down. The worst part of it is that problem has started with also when I am trying to open files or do anything with the laptop. It is too slow, what could be the problem?
    Master:
    Sergeant:
  • 482 Answers
Unplug it from the wall for 10 sec. and then plug it back in and restart.
Posted on Mar 16, 2008
Have had this lap top for right at 2 years,, just last few days, when I try to hibernate, it takes a long time to shut down, then when I start to "wake" it up, it shows that there was an un-nessary shut...
I don't know about the long shutdown time but I may be able to speed up the startup time.
(Assuming you have Windows Vista or 7)
Go to the Start menu and in the "Search" field type in "msconfig" (without the quotation marks" ")
Click the on "Boot.Ini" tab and check "NoGuiBoot". Now on the right where it says "timeout" change the 30 secs. to 15 secs.
Now click on the Startup tab. Tell me all the processes that are on here. If there's more than 15 or so then it's no wonder your computer is starting up slowly. This should dramatically speed up your PC and improve performance.
Jul 21, 2010 | HP Pavilion dv9000z Notebook
Tip
How to shutdown your computer very fastly in microsoft operating systems.
step 1: click start menu button
step 2: click on the 'run' button
step 3: in the box that appears,type in the command ''shutdown -t 01"
the computer will start shutting down in 01 seconds
Note: By changing the value after the letter 't' in step three, u can set timer to shutdown for the specified value
for eg: the command ''shutdown -t 15" will set the timer for shutdown to 15 seconds.
on Jun 19, 2011 | Computers & Internet
Tip
Here's how to create a shutdown shortcut on your desktop
Instead of going to the start menu, choosing shutdown, then waiting for the computer to shut all the programs down, you can create a shortcut on the desktop to do it quickly. You can create a shutdown, restart, or a logoff icon on your desktop which will work a lot quicker than using the usual buttons in the start menu.
1. Go to your blank desktop
2. Right click on a blank space and a menu will appear
3. Choose New from the menu
4. Then choose Shortcut
5. Where it says type the location of the item type in shutdown.exe -s
6. Then press next
7. Now enter a name for your icon. Mine is called SHUTDOWN NOW
8. Press next
9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r
Restarts your computer in 30 seconds.
shutdown.exe -l
This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1
Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot"
This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot"
The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu..
* -f will force everything to close immediately without asking to save anything.
on Jan 29, 2010 | Computers & Internet
Shut down
Go to the control panel select power option and check the settings.
Mar 30, 2010 | E-Machines eMachines Desktop PC
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
Emachine t6420 suddenly shutting down after about 15 min. - 1/2hr. Power button on HD blinking on and off slowly. Can get it to start up again by taking out the electric plug and waiting a min. and...
Check on the processor installed inside the computer's motherboard, it might be loosen and make sure it is properly locked. Also check for the fan. Make sure the cpu is properly ventilated to avoid overheating that might cause the shutdown.
Sep 28, 2009 | E-Machines T6420 PC Desktop
My sony computer reboot and shut down by it selt
right-click My Computer, and then click Properties
click the Advanced tab
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box
Clear the Automatically restart check box, and click OK the necessary number of times
restart ur pc and see take effects
Jun 22, 2009 | Compaq Presario SR1703WM PC Desktop
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
When i select shutdown computer it doesn't sitch off it restart again
Thanks for using FixYa.
You need to disable the Startup items from the MSCONFIG.
Start the PC and in the Desktop
Go to
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
Uncheck the program running and click apply. then try to shut down.
Let me know the result, I will further investigate and fix the problem.
Best of Luck & Have a Nice Day
Puneet
Oct 07, 2008 | Computers & Internet
Shutdown
plz check the power supply
Jul 01, 2008 | E-Machines T6420 PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
