My apex video/dvd player plays back my dvd's only in black and white.
  • dskoglund Mar 16, 2008
    Thank you, I have tried that. Everything is tight. The VHS part plays in color and the tv is brand new today. Before the old tv went dead, I had the same difficulty with the dvd's playing back only in black and white and I blamed the tv as it was on its way out.
  • 373 Answers
Be sure all your rca wires are good either by wiggling or replacing. If not the problem be sure the tv is ok and only then condem the dvd player. Try different input to tv also.
Posted on Mar 15, 2008
  • 19,396 Answers
Check the video cable it can be out of place or faulty, it is one of most common cause for bw picture.
regards
  • Ginko
    Ginko Mar 15, 2008
    Try also replacing cable if moving it does not fix it.
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Dvd is playing movies in black and white
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
Feb 26, 2012 | Apex Digital ADV3800 DVD Player/VCR
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
Only plays in black and white? what do we do?
Try a different cable, and a different TV if possible to help narrow down the problem.
it could be set for some other peculiar output mode; go into the configuration in the dvd player menu and verify that it is set for the type of TV you are using. normal composite video, (RCA), SVideo, Component Video, RGB, VGA, and Progressive Scan.
Dec 01, 2009 | Apex Digital AD-1110W DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
  • i'd test the dvd/vcr in a different tv
  • i'd test the tv with a different dvd
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
May 01, 2009 | Apex Digital ADV3800 DVD Player/VCR
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
No Color playing DVD just black & White
Have you tried playing the DVD in PAL60,NTSC 3.35 or alternately select the colour system on the TV manually rather than in auto ?
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Dvd plays in black and White
There are a couple of things you could try with this. One, is to make sure that the video input is connected properly. The second would be to make sure that the DVD that played in black and white automatically changed your settings to PAL rather than NTSC.
Jul 06, 2008 | Apex Digital AD-1110W DVD Player
DVD player is in black and white
do a scan for the TV tuner to select the right frequency. if the tuner is not properly tuned you will get a BW video..also check if the connections are nice and tight
Mar 05, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
