Haier XQG50-11 spin and dryer do not work
After two years using wash and rinse still work fine, but spin and dryer stoped working.
Same thing happened to my unit. It turned out to be the no spin switch which I never used anyway.
The switch had gone bad even though it was never used it. It was broken in the no spin state. The connectors on mine were a bit chared looking.
Take the top cover off the unit and remove the two wires from the no spin switch. Place a jumper between these two wires bypassing the switch or replace the switch.
In the no spin cycle the unit will not spin or dry.
I bypassed my switch and the unit runs perfect again.
Posted on Aug 22, 2009
Haier encore top load will wash but when it start to rinse want pump water out..I take drain hose lay on ground and it works fine whts the problem
there could be something stuck in the impeller of the pump not letting it spin , no power to the pump motor or the pump motor has burnt out or the impeller is loose on the pump shaft
Jan 09, 2016 | Haier Washing Machines
How can I fix the LED monitor so the cycles do not change mid cycle?
It sounds like a control problem. I assume it is electronic, and if so try another control board but be sure you can return it if it does not solve your problem.
Jan 11, 2015 | Haier Hlp23e Portable Top-load Washer
My Haier hlp21n washer will not rinse, spin or drain. Have had it about 2 yrs with zero problems. Last used, worked perfectly; not even a hint of problem. The next week I hooked it up to do clothes & it...
There may be something stuck in the pump. This could cause no drain and of course it won't spin with water in it. I an not sure if it would agitate or not. I am not too familiar with Haier machines but I did have one with a jammed pump and it didn't work until the object jamming the pump was removed
Jun 27, 2014 | Washing Machines
My washer will fill and wash but when it gets to the rinse and spin cycle than it just stops and wont draiain
gwt450aw mine was washing but was not spinning and was loud like many others have posted. Seems the electronic drive motor had washer type ring inside the middle of the motor that was wavey from heat guess if happens over time. The friction was over heating the motor till it would stop working. Took that part off works fine. Once you've inside you can tell there is no need for it. Given the position of the motor. FYI the drive motor is under 10 year warranty from haier with proof of purchase for the date.
/uploads/images/6_9_2014_9_24_19_pm.jpg
Feb 04, 2014 | Haier GWT450AW Washer
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
My haier washing machine doesnt work properly
get rid of it. I had two of these that did the same thing. people all over the internet are suffering with haier washing machines! They are utter rubbish and I will never buy haier again!
Jul 30, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
May 25, 2008 | Malber WD1000 Front Load Washer/Dryer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Final Rinse
im a repairman and just ran into that same problem on the ge washer. the problem is the control board. That control board is expensive, but it will fix the problem
Feb 02, 2007 | GE WJSE4150B Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
