Question about HP Compaq d530 SFF PC Desktop
How do I remove the Processor Fan to clean the dust in the heat sink
  • ivanvalles Mar 15, 2008
    how do I remove the Processor Fan to clean the dust in the heat sink because the computer freeze after a few minutes of use.
    thanks
  • ivanvalles Mar 16, 2008
    find the clips and unclip it
    thanks for the help
  • 85 Answers
Well, sometimes there are screws, sometimes there are clips. Unclip the clips, Unscrew the screws, and joy to the world.
Posted on Mar 16, 2008
Machine running, fan suddenly speed up too high, so i log out shut down, powerup/shutdown in seconds with flashing red light, continuosly
This has been a problems that is really easy to fix as long as your a bit careful. The problems is the design of the heat sink on the processor, the design flaw makes it possible for dust to collect on the heat sink on the processor allowing the heat to build up very quickly when using the processor a lot which tells the fan to speed up to attempt to cool things off but because of the excess dust it cannot do so.
On the e-machine it is easiest to use compressed air to clear the dust on the heat sink for the processor, however do not have the computer turned on when doing the cleaning, and if your using a air compressor blow gun, you should limit the pressure to 100 lbs or a little less and then be careful not to blow directly on the fan so the fan spins up (by the air flow) too fast because it can damage the fans bearings.
Note: this machine will collect a lot of dust in the heat sink so when blowing it clear it will produce a dust cloud, you may wish to do it in an area where dust will not be a problem for other things, people, or pets.
Aug 28, 2013 | E-Machines eMachines Desktop PC
Clean heat sink
Yes you can, remove the cover off the desktop computer to get access to the fan and heat sink over the CPU.
Use a stiff brush to loosen the dust off the fan and heat sink and vacuum the dust off the fan and heat sink. You may need to use a can of compressed air to blow the dust off the fan and heat sink then vacuum the dust out.
Aug 24, 2012 | Gateway GT5220 PC Desktop
My armada e500 processor is built-in and processor not working
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 13, 2012 | Compaq Armada E500 Notebook
IBM x3400 server hanging / chipset & processor heating, but cooling fans are working properly.
Make sure that the fans are working at proper speed (not stuck or slow).
Secondly, heat sink could be clogged due to dust or not properly seated. Clean it if required. You may remove it, clean its fins and replace it back (for both processors if required) . Don't forget to apply THERMAL PASTE between the heat sink and the processor (If you remove the heat sink). The Thermal paste conduct the heat from the processor to heat sink which is then dissipated into air by the processor fan. You may also consider adding an additional fan, if required.
Also, place the PC at a well ventilated location so that the cool air enters it from the front and warm air leaves from the back.
Sep 26, 2011 | IBM x3400 Server
My fan keeps speeding up , then it slow downs what causes this? an how can I fix this?
which fan is doing this? Mostly likely it is caused by dust or overheating. Use a can of compressed air found at any electronics store to clean the dust out from inside the computer. If that doesn't solve the problem I would next try replacing the fan.
thank you,
Lee
Sep 21, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
My nv7802 overheats and shuts off,fan is running but the heat sink gets very hot
The fan may be running too slow (faulty bearing) or the fan and heat sink assembly may be clogged with dust.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Dec 30, 2010 | Gateway NV7802U Notebook
Otiplex 760 will power up breifly and shut off as if the thing was unplugged , sometimes will stay running for a few minutes and sometimes will shut off immediatly. I cleaned the old heat element compound...
1. Try blowing the dust on the motherboard, if any hard dust is present, use soft brush to clear it.
2. Again remove the Heatsink on the processor, completely clear the compound using soft cloth, There should not be any hard particles or dust left, apply heat sink compound on both the heat sink side and on the processor, put back the heat sink and fan.
3. Check whether the power button on the cabinet is not struck and functioning if possible try to replace the button.
4. Blow the dust even from SMPS or try with another if handy.
Sep 05, 2010 | Computers & Internet
Are there diagrams/videos of cleaning the processor fan in a sony vaio VGN FS740/W?
Not really, remove the screws on the panel over the fan, use a stiff brush to loosen the dust on the fan and heat-sink and then use a vacuum to remove the dust.
Mar 31, 2010 | Sony VAIO VGN-FS740/W Notebook
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
HP Compaq d530 SFF PC Desktop Logo
591 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
