Question about Infinity BASSLINK Car Subwoofer
Basslink my basslink just hums really loud. No music. With or without rca cables jus humms?
    Sergeant:
  • 300 Answers
My first suggestion is to check the gain setting of the unit. If it's above the 50% point, drop it down.
Second, verify your ground connection is good, short, and solid.
Posted on Mar 18, 2008
SOURCE:
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
The tweeter of my mackie srm 450 V2 makes a quite loud noise (humm). this nois was there right from the beginning, and mackie told me, that this was usual....the older 450´s did not make this kind of...
The latest 450v2 include this metal portion 1 to isolate AC lines over IC's, metal part 2 is include in all versions, some technician remove them and that creates more hum at idle levels, by having both the latest 450v2's are the quietest of the v2's.
V1 did not use switching power supply, they use discrete circuit and that is why they are a bit quieter
Aug 04, 2010 | Mackie SRM-450 System
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Humm noise coming from 10" 100watt sub only plugged into wall...
If you're using it first time, check the sub cable u're using, low-quality rca cables can easily pretend to act as an antenna and pick up parasite and hum from electric lines or from other devices, also another factor is too-long cable. If u're using a cable longer than 5m, it should be really hi-quality and well screened. Or the hum is inevitable. I hope this helps.
Jan 03, 2010 | Sony SA-WX700 Subwoofer
Bad Humm out
First disconnect all inputs. If hum is still there, PROBABLY the filter capacitors have gone bad. Replacement is the cure.
IF there is no hum without any inpout cable connected, there is a ground loop and either the ground at the inout connector is broken, or your cables and guitar may have a problem.
Nov 15, 2009 | Marshall Amplification Marshall MG250DFX...
Loud Humming
Many times a "humming"sound is caused by bad signal, caused by things like, bad rca cable, bad rca ground from the radio, or even a bad ground in from the amp to the car.. Wiggle your rca cables at the input to the amp, and see if it changes the hum at all.. If not take a short peice of speaker wire, and wrap one side arrounf the outside metal at the end fo the RCA jack, and then touch the other end to ground, and see if that makes the humm go away. If the humm goes away at that point then you need to have your radio replaced, or repaired. if neither of these do anything to the hum then check for tight ground connection to the amp, and to the car..
There could also be a problem with the amp it's self, but this kind of thing is hard to diagnose over the web, so try those things, and let me know what happens..
Aug 15, 2009 | JBL Audio Players & Recorders
I have a Crown Power Base 1 AMP, with a buzz. It
Buzz through speakers usually means it is picking up humm from a power source. Check your mixer and amp input (gain) levels. If one is turned up really high you will get buzz. If that doesn't work check where it is plugged in. Is it sharing power with another electronic piece of equipment? You can also buy a power conditioner (I believe it is called). It will put out "clean" power (power without Hz humm). They can be expensive though. Less exspensive mixers will put out humm. Lower that gain as low as possible and raise the amp gain. Or vice verse
Jun 23, 2009 | Crown Audio Players & Recorders
I have a loud humm in my bose lifestyle 28 system
Turn on your bose so you can hear it hum. Go to the back of your cable box and remove the co ax cable connected to "cable in". If the humming stops, the sheilding on your cable is no longer grounded. Purchase MPAV800 or similar surge protector to run cable line through it and get it grounded.
Feb 02, 2009 | Bose Lifestyle 28 System
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
164 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
