Condensing unit model: AC5048BCRSA what are the BTU's for this unit?
    Problem Solver:
  • 5 Answers
The 48 indicates 48,000 btu's. 12,000 btu's = 1 ton of cooling. this unit is a 4 ton condenser
Posted on Mar 16, 2008
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
What evap coil can be efficiently used with a 10 seer rheem raka-024jaz condenser
Hello, if the outside condenser is 2 ton than the inside evap coil should be 2 ton aswell. There are 12,000 btu's per ton and the number 024 in the model # represents btu's per ton so you have a 2 ton unit.
Jun 25, 2012 | Heating & Cooling
Danby DAC10011E 10000 BTU window air conditioner not draining water? does it have some sort of self evaporating technology? I can hear water inside when I turn it on and/or off, but none draining out the...
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound"
Jun 18, 2012 | Danby Dac10011e 10000 Btu Window Air...
Need to know tonnage of goodman condenser model # ssz140361ab
If this is the correct Model number, you have a 3 ton unit. 036=36,000 btu. 12,000 btu per ton.
Shastalaker7
A/C, & Heating Contractor
Apr 01, 2011 | Heating & Cooling
What size BTU unit is my Crarrier model 38ck036330 condensing coil ?
The model you gave is for a 3 ton or 36000 BTU unit...that is what the 36 stands for in the model number...
heatman101
Aug 24, 2010 | Carrier Heating & Cooling
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY...
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Aug 04, 2010 | Honeywell International Heil Quaker...
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
