Question about Acer Aspire 3000 Notebook
Shuts down for no reason
I have had the problem the battery, keyboard not working. Once I took out the battery everything works get. I now am having a problem with it shutting down instantly while I am in the middle of doing something. Any suggestions?
    Scholar:
  • 105 Answers
With the battery removed any interruption of the AC power will cause the laptop to cut off. The power adaptor may be faulty or intermittent or more likely the socket on the laptop motherboard may have a dry jointed connection. These problems would not be apparent with a charged battery fitted.
Otherwise [especially with P4 type processors] overheating could cause cutting out - clean any fans and make sure vents for air intake are not blocked [by bedding etc].
Posted on Mar 16, 2008
Voice light computer has been shutting down and will only work after rebooting with power switch. At first it shut down rarely, maybe once every two months. Then it became once a month, once a week and...
This is likely one of two things:
A power supply issue in which case you have the power supply replaced.
The server is overheating. There could be many reasons for this: Dust, loose parts, bad ventilation, etc.
Mar 06, 2011 | Comdial SmallOffice Lite Voice Mail Server
Everything was working fine. I changed the batteries in the mouse - wireless keyboard works, mouse doesn't. I took batteries out of both, unplugged receiver, and started over. same problem!
Only thing Ican suggest is the batteries in the mouse are in wrong, or you have a bad battery. Try swapping the batteries from the mouse to the keyboard and see if the trouble follows.
Dec 28, 2010 | Computers & Internet
Fuji S7000 shuts itself down...without a reason
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
My girlfriend was driving to class when her speedometer, blinkers and cd player stopped working. She pulled into a parking lot and turned it off and then back on, the car didnt run. When i got there 10-15...
ok, try cleaning the battery posts, and if its older then three years change the battery. Once everything is ok check the charging system of the vehicle. The reason your power steering/brakes went out is the engine was off, power sterring works of a pulley on the engine and the power booster for the brakes works off the engine vacuum.
Aug 28, 2009 | 1998 Ford Escort
Touch pad and keyboard freeze after startup
Battery problem, remove battery... fixed!
Feb 19, 2008 | Acer Aspire 5670 Notebook
Travelmate 2310 keyboard and touchpad problem
Boot up the system (without the battery).
When the system runs normaly then place the battery on its normal bay.
Shut down bij removing the power from the system.
* Make sure you have not installed any Windows power saving tools, meaning let it run on the battery till it dies *
Wait till the systems shuts down by itself.
Boot your system again (with the battery in its bay and everything will work out fine.
Shuting down by removing the power support (AC) booting up AND your keyboard with touchpad will work again.
So intill you have a new battery, you need to shut-down by removing the AC power and leave the battery in its bay.
You can not shut-down on the normal way any more untill you have replaced the battery.
Feb 04, 2008 | Acer TravelMate 2300 Notebook
Keyboard and mouse stopeed working
make sure that you put the keyboard and mouse back in the same usb ports you took them out of and it will work, but if in different usb ports than before you will have to install the drivers again.
Aug 17, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Acer Aspire 9502WSMi Shuts Down When Upper Parts Are Pressed!
This sounds like a short of some kind from the motherboard touching either the body or some other peice of hardware, or you have a broken soldered joint on the board causing the problem. I would take to a qualified repairer.
Nov 24, 2006 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
