Question about Canon PowerShot SD600 Digital Camera
Lens error canon L3 coolpix - Canon PowerShot SD600 Digital Camera
  • jodymincey Sep 08, 2008
    When I turn the camera on the lens moves in and out and then gives a lens error message.
  • shirljenning Mar 02, 2009
    I have a similar problem. My lens does not move in and out but it gives me the lens error and shuts off. Any other suggestions?
  • 51 Answers
OH NOES!!!! THE DREADED LENS ERROR... frankley on this particular camera it is very easy to fix... just take out the battery for about 30 min and make sure it is charged. and put it back in and it should work this happened to me...
Posted on Feb 11, 2009
bmwrider
  • 215 Answers
SOURCE: Lens problems
This is an awkward one. If you were clever enough to replace or repair the lens assembly you wouldn't be writing here so all I can advise is to have a very close look at the lens and see if you can notice any slight variation in it's positioning. If you can see part of the lens is pushed slightly to the left then with a very fine blade lever the lens from the left to the right and at the same time switching on. It's often easier to get someone else to do the switching on and off for you. Make sure the batteries are fully charged too. If you can get the lens to come out a little way then keep trying and it's possible it will realign and start working. Of course it's possible you've fractured a nylon gear or two so that will be a specialist job. All I can tell you is that if you can't get the thing to work yourself it's going to be very expensive. Maybe another check on Ebay for a transplant possibility. BMW
Posted on Jul 28, 2006
advance
  • 107 Answers
SOURCE: Lens error
The most common cause of this issue on the L3 is an impact which dislodges the focus element in the very front of the lens. The metal platform that the focus system is mounted to is attached with 1 screw and is able to flex slightly under stress. When impacted it flexes and allows the focus drive to become misaligned. The lens still technically works but the camera senses that the focus is jammed and leaves the lens extended so no components will be damaged by retracting. This repair costs $145 at my shop, not an economical repair for this camera. Some parts of the focus element are accessable from the front of the lens. You can remove the metal cover (it is glued down). Generally you will not be able to re-install the lens barrier, but it can be removed without harm to the camera. When you remove the plastic plate which carries the lens barrier you will see a small metal gear, this is the base of the focus drive.
Posted on Jun 16, 2007
t00nz
  • 4738 Answers
SOURCE: LENS ERROR
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE: nikon coolpix l3 lens error
i solved this problem by calling nikon. they said to fully charge the battery for a couple of hours. mine didn't work, so i called back and they told me to send it in for a repair and that's what i'm doing because i have a 4 year warranty on mine.
Posted on Feb 21, 2008
dlundmark
  • 797 Answers
LENS ERROR simply means there is a problem with the lens.
If the description is more detailed it would help.
Type of camera in the post always will help.
When the error started is helpful as well as how long you had the camera, as how it has been treated, did it ever get dropped, or had an impact of any kind?
Remember that digital cameras are very fragile, and should always be treated as if they are eggs, so to speak. Also the LCD is very easy to break if thrown into a purse, or some other carry bag. The camera should always be used with the wrist strap around the wrist, and put back into a padded case when done.
Lens errors can result in a number of problems.
The lens may be out of sync, or the guides internally could be off track.
Some of the internal parts, such as the gears could be broken (you will usually notice a grinding or other noise if this is the case).
There could be some dirt or sand in the track, thus causing the lens to stop or jam.
If the lens is cocked to one side, that is usually the result of an impact when the lens is extended. Sometimes this can be fixed by gently pushing the opposite direction when starting the camera.
Take care,
Posted on Jul 26, 2008
Coolpix l3 lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2008 | Nikon COOLPIX L3 Digital Camera
NIKON COOLPIX L3
See my posts on this problem. By forcing the lens with you fingers into the camera, it may put it on track. This can damage the camera even further, but may be worth a try. You can try to pull it out when starting, and then pushing in on turning it off.
Worth a try, may work.
Apr 12, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error on nokon coolpix
Mar 14, 2008 | Canon PowerShot SD600 Digital Camera
LENS ERROR
buy a new camera ya idot
Dec 03, 2007 | Nikon COOLPIX L3 Digital Camera
Lens stuck in the out position
Please reload the Firmware and your problem will be solved.
Nov 23, 2007 | Nikon COOLPIX L3 Digital Camera
Lens Error.
nikon coolpix 4 lens error help!
Nov 11, 2007 | Nikon COOLPIX L3 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
48 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
