Question about Car Audio & Video
My A3201Q Yes i have an audiobahn a3201q and recently it went into protect i removed all the output wires all that is connected is power and ground and remote and it still stays in protect any helpful tips on how to repair or info on a place i could get service done in the Nashville, Tenneessee area by any chance?
    Novelist:
    Champion:
  • 218 Answers
Sounds like a fried output section. Sorry I am not familiar with the Nashville area. Maybe a Google search would turn up something. Good luck.
Posted on Apr 22, 2008
    Problem Solver:
  • 4 Answers
Try unhooking the power, ground, and remote wires for a couple of minutes, also check all fuses on amplifier and fuse for power cable (usually under hood around battery), and don't forget to check ground wire connection for "good" contact.
Posted on Mar 31, 2008
Hello, my problem is how can i wire 2 subs that are different in ohms(one of them is 2ohms & the other one is 4ohms) so that i can make them both into 2ohms? i want it to be 420wX2@2ohms
YOU ARE GOING TO HAVE TO ADD ANOTHER 2 OHM SPEAKER IN SERIES WITH THE ONE YOU ALREADY HAVE THEN pARALLEL THOSE TWO WITH THE OTHER 4 OHM SPEAKER YOU HAVE
May 30, 2011 | AudioBahn A3201Q Car Audio Amplifier
A4004T AUDIOBAHN HEARTBEAT FROM AMP WITH BLINKING POWER LIGHT BUT NO PROTECTION LIGHT. UNPLUG SPEAKERS NO PROBLEMS. TRIED NEW WIRES, NEWER BIGGER GROUND. SUPPLIED WITH 40AMP FUSE NEAR BATTERY AND 2 20AMP...
If you disconnet you speakers and there is no problem, Then it's your speakers.
1. try your speaker wire in one port at a time (may have blown one of the outputs)
2. Check the speaker connections directly on your speakers (not loose or damaged)
3. try a different speaker all together and see if you get sound etc.
4. try a different wire from your speakers to your amp (wire may have shorted out or have breaks)
Hope this helps and please rate. If you require further info please comment and I'll get back to you asap
Mar 19, 2011 | AudioBahn A4004T Car Audio Amplifier
I Have a audiobahn a1800dt its almost identical to this amp, i played it for a while with no problems, until i hooked up some crappy subs to it and it went into protection mode without comming out of it....
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Please check speakers impedance A thumbs up would be greatly appreciated if this answer is helpful to you
Feb 03, 2011 | AudioBahn A18001DQ Car Audio Amplifier
Audiobahn a8002t amplifier in protection mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. audiobahn-a8002t-amplifier-in-protection-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Dec 21, 2009 | AudioBahn A8002T Car Audio Amplifier
No sound protection light on.
Either blown subs, or bad amp.. Disconnect the subs, and try turning the amp on, if the amp is still in protect then your amp is bad, if the protect light goes off, then your subs are bad, or possibly wired at to low of an impedance, but I don't think that will trigger the protect on an Audiobahn amp.
Aug 21, 2009 | AudioBahn A2002T Car Audio Amplifier
My amp automatically goes into protect mode
There are 4 reasons an amplifier tries to protect itself.
Overheating - thermal shutdown.
Over Impedence - The subwoofers installed are not configured into a load the amplifier can handle.
Output is grounded - a positive wire strand may be touching the ground terminal - a wire may be shorted, or a speaker voicecoil is blown.
Intennal problem - Output on amplifier blown, or some other component has failed.
Check your wiring to the amplifier again - if all is good - disconnect the speakers and try to power on. If the amplifier turns on normally - test the speakers for blown coils.
If the amplifier still goes into protect mode - the problem is internal and needs professional repair.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | AudioBahn A2301 2-Channel Class A/B Mosfet...
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
Audiobahn A1500HCT in Protection Mode
try just hooking up a power wire and ground wire only. disconnect your subs from your amp along with the remote wire and RCA's. if you have some jumper wires or run a wire from the power terminal to the remote wire. YOUR amp should come on, if it still stay's in protection mode it might be shot... hope this was helpful, i couldn get my a2300hcx to come on and tryed this and it came on turns out it was my remote wire was bad of the head unit...
Nov 13, 2006 | AudioBahn A1500HCT Car Audio Amplifier
like many other problems people have with amps it is usally a ground issue, grounds have to be in very good spots especially with high power amps, move your ground to a different spot, with zero guage wires really is all you need, double grounds would be inopropriate here. hope this helps
Oct 06, 2006 | AudioBahn A4125HCT Car Audio Amplifier
My amp quit working
ok I thought I anwered this one but first thing to try is disconnect all your speakers and see if the light goes out if it doesnt then your gonna need a schematic and a working know how on solid state amplifiers. first check al the outputs for the speakers for dc If theres dc on an output then that output device is shorted or leaky. Ive have open drivers as well as current control transistors leaky or shorted to that made the protection come on.. Good Luck
Apr 07, 2006 | AudioBahn A6004T Car Audio Amplifier
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
