Question about Philips DVP642 DVD Player
DVP642 DVD Player is only working in Audio mode
My Philips DVP642 has worked perfectly for over a year now. But suddenly now its only working in Audio mode. It recognizes the DVD but no picture turns up. I can only hear the audio. Any help appreciated.
Thanks,
Shweta
  • swashsuckler Mar 30, 2008
    I have a similar issue. I've had mine for a few years and it always worked fine, then I replaced it with a newer one and it sat unused for a few months. Then I tried hooking it up this weekend and it plays audio but no picture. I've tried hooking it up two ways, with component video cables (this gives an actual scrambled image on the DVDs AND the Philips screens) and with a single video connection (yellow connector), which gives no image at all. Not sure what could have happened, but if there is a solution, I'd be glad to hear it! I have tried two televisions, with the same result.
  • James Martin May 11, 2010
    How is your DVD player hooked to the tv, what cables are you using?
Mine does the same. Cannot get a picture using the Yellow RCA output. Use an S-video cable if you can - it should still work. If you get a black and white picture using the S-video output, go to MENU > VIDEO page and change the output from PyBywhateveritis to S-video and the color will come back. I only found out mine was broken when I needed to use the s-video cable for something else and tried switching to the Composite Video (RCA) to no avail no matter how many cables or TV inputs I tried.
Posted on Jun 14, 2008
There is no audio
Hello
The main board of your Philips DVP should be trouble shooted. Actually this is a very skilled work, needs a sound knoledge in electronics, and expereince in repair. The fault lies on its main board itself. OK.
Oct 03, 2011 | Philips DVP642 DVD Player
In my Philips DVD players, recently I have tried to play few film DVDs, and it showed region error/or wrong region. Could you please help me out with this and tell me what should I do?? I talked to the...
The DVD you're using is probably from elsewhere than the region you live in. It is almost certainly possible to temporarily change the region by using a trick which will not damage your machine in any way. Google "Philips DVP642 region hack" and there will be an answer.
Dec 18, 2010 | Philips DVP642 DVD Player
I have a Philips DVP642 DVD player. It has worked
First try a soft reset... unplug for 20 minutes.
Otherwise - the laser is dirty or misaligned.
A Repair shop can clean and align for about $50.
It takes specialized equipment and templates to align the laser - not something you can do on your own.
Lens cleaner discs don't work.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 27, 2010 | Philips DVP642 DVD Player
No audio. Video O.K. PHILIPS DVP642/37
User manual for DVP642/37:
http://www.p4c.philips.com/files/d/dvp642_37/dvp642_37_dfu_eng.pdf
Connections on page 13.
Audio setup from page 28. Page 28:
For simple stereo setup use [Downmix] > [stereo]:
[LT/RT] requires a Dolby Pro logic decoder.
Aug 31, 2009 | Philips DVP642 DVD Player
Will play sound but no picture
1.check your video cable between DVD and TV.
2.in back of dvd one yellow socket only for video out others for some other purpose.
3.open tray conditon .-go to system menu on Remote -go to general set up page-video set up -and switch of .progressive -in OFF-mode.
then try it for video play back
4 if not ok replace the video decoder ic.
Nov 12, 2008 | Philips DVP642 DVD Player
My Remote Doesn't Work
Contact universal remote and see if they have a code for the unit. 919-573-7854
Aug 08, 2008 | Philips DVP642 DVD Player
Philips DVP642 No Disc
clean the disks as well as possible with cleaner and soft cloth. the problem is not the disks, but the fact that the DVD reader has become really sensitive.
if that wont help, open up the case (screws on sides and back), and clean the DVD mechanism and lens as best as possible.
you still might be SOL, but its worth a try since its out of warranty, and a replacement player is $60.
Feb 12, 2008 | Philips DVP642 DVD Player
Tray is not opening
To open the tray this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down with practice) 3)Tap gently, yet briskly with fingertips at area in the attached pic, that the red arrow points to I think the problem is that the tray becomes unbalanced somehow. Because when a DVD is in, the drive opens fine, only when there is no disc do you have to tap on the unit.
Aug 13, 2007 | Philips DVP642 DVD Player
Philips DVP642 DVD Player Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
