Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Flow Indicator Not Moving, Not Dispensing Anything
Neither water nor cleaner is being dispensed when holding the trigger, and flow indicator isn't moving. Checked belt, cleaned everything out, checked seals...can't seem to find any problems.
  • 2 more comments
  • DirtyDi Mar 18, 2008
    Thanks for the advice. Water isn't squirting out, and I checked the tank base and valve as well as the cleanser valve. So it must be a bad pump?? Any suggestions on how to double check if it's the pump?
  • Anonymous Mar 25, 2008
    i need a page showing me parts desimbled standing up, don't know my parts on this machine, no guide thank you
  • coke13 Mar 26, 2008
    no water dispensing and flow indicator not moving?
  • Anonymous Mar 15, 2014
    Won't dispense water flow meter reading nothing
    President:
  • 1,673 Answers
Does water squiret out of the hose, if it does, then check the heater inside the handle to see if it is clogged where the 2 water lines hook to it. The other reason, you may ghave a bad pump. But check the back edge to make sure the top isn't coming loose from the base. Check the bottom of the tank to be sure round seal is on the tank on the cap and valve. Sometimes they come off and wind up in the hole.
Posted on Mar 15, 2008
  • Lauren Junge
    Lauren Junge Mar 18, 2008
    Sorry, no real way to check the pump, you will have to replace it, they do go bad.
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
Feb 07, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
The wand will dispense water but no water is dispensing through the floor mechanism.
The User Guide gives you steps for reduced spray or no spray. But, I have seen some pinched hoses as the cause that can fixed by simply removing the hose completely and straightening it out. The Guide reminds you that the Bladder may be empty, the Heater tank may be empty, the tanks may not be seated completely, or my favorite the filter may be clogged. If you haven't been cleaning the filter after each use this may be a start. The first is where is it? There are actually two filters: One is located on the tank cap. It looks like a screen. Clean any particles that may have collected on it. The second is under the Flow Indicator: Turn the FLow Indicator cap counter-clockwise to remove it, remove the rotor, then remove the filter. Clean the filter and replace items in reverse order. If after that you still have a problem you can contact Bissell Consumer Care at 1-800-237-7391.
Nov 28, 2015 | Bissell 8910 ProHeat Clear View Upright...
Bissell proheat cleanshot 2x won't stop putting out cleaner and water, the little dial won't stop spinning
First clean the Flow Indicator filter. Turn the Flow indicator cap counter-clockwise to remove it. Lift the rotor and the filter under it out. Clean the filter and reinstall in reverse order. Make sure you have unplugged the unit before working on it. Then clean the lint filter on the heat tank cap (it looks like a screen) and reinstall it. There's not much more to these so if that doesn't work call the Bissell Consumer Care at 1-800-237-7691
Oct 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water will not dispense
I'd clean the small filters. One under the Flow Indicator: Unscrew the Flow Indicator cap to remove it. Lift out the rotor and the filter is directly under it. Lift the filter out and clean. Replace in the reverse order. If that didn't work then call Consumer Care 1-800-237-7691. Hope that Helped.
Sep 26, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover troubleshooting
Hi! Try these quick and easy steps to get the water from your hose to spray.
Assemble the hose to the unit.
While holding the hose at an angle towards the ground, pump the trigger about 30 times. Turn the cleaner on then squeeze the trigger for 30 seconds.
If the water is still not dispensing there may be soap residue bulid-up clogging the nozzle/valve. Try soaking the trigger end in warm water for a couple hours, then repeating the steps above.
If the cleaner is still not dispensing from the hose but dispenses from the unit, a replacement hose may be needed. Follow the link below to order a replacement hose for your cleaner. Search Results
Aug 23, 2014 | Hoover F5826-900 SteamVac Upright Wet...
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
It turns on, it makes the noises, the brushes are spinning, but the water/cleaner isn't getting to the floor
Hello! Sometimes it is necessary to prime the trigger to get the solution flowing. To prime the trigger, recline the handle and pump the trigger vigorously 60 times. Then, power the unit on and squeeze the trigger for about 60 seconds. The solution should begin to flow. It may be necessary to repeat these steps a few times. To avoid internal damage be sure you are only using the cleaning solution recommended for this unit. If the unit is still not dispensing we recommend taking the cleaner in to a vacuum repair center for repair. Follow the link to locate the nearest authorized service center to you. Service Center Locator
Jun 02, 2014 | Hoover Steamvac F5860-900 Vacuum
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
The water tank and the solution tank both have red gaskets that attach to the bottoms of the tanks. Make sure they are on properly, I just had the same problem and spent hours taking apart the machine and inspecting lines to find out it was a gasket.
On my machine the red gasket for the solution got stuck in the chasis for the machine. The bissel website alludes to this, but isn't very clear.
Other posters talk about the heaters, or the lines being clogged and I immediatley inspected these areas, turns out it was a gasket that was hiding in the chasis. Both the water tank and the solution tank should have one, and make sure they don't get nestled in the chasis!
Apr 13, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
288 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
