Question about Philips Magnavox MWR10D6 DVD Recorder
Magnavox recorder ok, i have everything supposedly connected right, OUT of my vcr INTO my recorder OUT of my recorder INTO my tv. I know the vhs is not copy protected. my recorder shows up on my tv screen but my vhs dont. isnt it supposed to show up when i press stop on my recorder? Do I have to change my output setting on my recorder? Please help!!
  • 1 more comment
  • Anonymous May 03, 2008
    I am also having problems hooking an "in source" into the Magnavox CMWR10D6. I have everything else working. I have my satellite hooked into the Magnavox, which is hooked out to a RF modulator to my older TV. I have an LG DVD HDD (only working like a VHS since its burner is shot!!) hooked from its OUT to the IN of the Magnavox. I can't seem to see anything from the LG at all. Is there an input selection key or something on the Magnavox remote to get these two to communicate?? Please help.
  • bugajafe Jun 04, 2008
    I had
    OK. Can you let me finish my sentence? I had my Magnavox CMWR10D6 plugged into a SD set top box, which worked fine. When I upgraded to a HD set top, I just switched over the leads and assumed everything was fine. It took me a while to realise that the DVD and set top box were incommunicado. I have tried as many lead combinations that I can think of, as well trying the source on the remote. It makes the recorder component totally superfluous.set box is olin brand, model hvbt-1800, i can receive one or the other signal/dvd/tv, but not without phsically altering the leads.
You casn look to see if you have a input on your remote and hit that to see if you can see something else
Posted on Sep 04, 2008
I have Magnavox DVD player/vcr DV225MG9, does it record from vhs onto dvds? And if not, what do I need to get so that I can copy all of these old vhs movies to dvds?
it won't record dvd's its only a dvd player. only the vcr records
if the vhs movies your trying to record are movies like star wars and stuff like that it's copy protected and no worth the trouble. if it's home movies or something you recorded from tv they might work. if you get a dvd recorder/vhs player.
Jul 20, 2015 | Magnavox Televison & Video
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd to vcr?
Plug the DVD connections into the INPUT on the back of the VCR. This is sending the signal from the DVD player INTO the VCR.
If you are familiar with the VHS to VHS, then remove the VCR and replace it with the DVD player.
I hope this helps :)
If the question changes it will send me an automatic message. So if this was not enough info, just let me know! I'll actually hook mine up to record this way then I'll be able to tell you step by step if need be.
Jan 11, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't setup Magnavox DVD VCR recorder
Put your TV onto chanel 3 to pick up your Magnvox signal
Jan 06, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox MWR10D6 DVD Recorder Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
