Question about Leviton (102-5G108-RW5)
3 speed light/fan switch
I need to know how to install this from the old light switch.
Como ponchar los jack
Posted on Oct 13, 2008
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a 3 way fan light switch but wires don't match the colors on my hamton bay fan what wires go where i have a black wire and a brown wire and a grey wire on the switch in the hamton bay i bought...
It takes 2 testers.
699b7e0.jpg regular tester
Continuity tester has battery and light bulb.
Use regular tester to find Hot wire that feeds old-switch.
Remove old-switch from fan
Strip back wires
Separate wires so they can be tested.
Turn on power.
Test each wire to bare copper wire -or- to green wire -or- to metal part of fan
One of the fan wires will light up tester.
This is the Hot wire.
Mark Hot wire.
Mark which color wire on old-switch went to the hot wire.
Use continuity tester on old-switch.
You know which wire is hot-on-old-switch
Pull chain and test hot-on-old-switch to both of the other wires.
When tester lights up, mark this wire.
Pull chain again and test hot-on-old-switch to both of the other wires.
At some point when you pull the chain, the tester will light up both the other wires.
This is the high speed.
Use continuity tester on new-switch.
Repeat the test for old-switch.
Identify which wire will be the Hot wire by process of elimination.
Mark this wire.
Identify high-speed wire.
Pull chain again, and tester lights up on medium speed.
Pull chain again, and tester lights up on low speed
Identify these wires and match pattern to the old-switch
If you need more help, add a comment, and I will answer
Oct 29, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Need a replacement, where do I get one?
If I understand correctly you have a 3-speed fan.
And you need a 3-speed replacement pull-chain-type switch
Lowes carries 3 speed fan switches in the light fixture department.
These switches have multiple wires.
At any given time, there is one-and-only-one wire that connects to power from wall switch.
Lets call this the Power wire.
As you pull the chain, the power passes through the switch and goes to one-and-only-one of the other wires.
The other wires connect to windings in the motor.
The different motor windings control fan speed.
The key to replacing the switch is recording where each wire went before you disconnect old switch.
Once you know which of these wires is the Power wire, then you can test other wires with a continuity tester.
You also know the pull-chain sequence is OFF - HIGH - Medium - Low
Mark wires in fan and mark wires on old switch.
Pull out old switch.
Use regular electrical tester to find which wire in the fan is the power wire (separate wires, turn on power and test each wire to metal part of fan)
Now test the switch wires.
The switch is out of the fan.
You marked the wires so you know which wire is power wire.
Put the continuity tester on the power wire.
Test power wire to each of the other wires.
Click the switch and test to each of the other wires. Mark which wire lights up continuity tester.
Click the switch and test again. Mark which wire lights up continuity tester.
Click again, until each wire is marked in the sequence.
When you click the switch and no wire lights up, then that is the Switch OFF position.
Do the same test on the new pull-chain switch.
Connect the wires to match your testing.
Oct 25, 2010 | Westinghouse Electric Westinghouse...
We have a Hampton Bay ceiling fan (about 10 yrs old) don't know the model. It will only turn 1 speed? When trying to change speeds with the chain pull it stays the same. It quit working for a while and I...
the fan changes speed by inserting a capacitor of different values in series with the motor .. direct drive to the motor is the fastest speed .. a large capacitor in series slows it down a bit and a smaller capacitor slows it down more ... so if your fan is running at full speed all the time then one of the capacitors is shorted or the switch is bad .. if its stuck on one of the lower speed settings then the switch has a bad contact .. the capacitors are mounted together in a small box with several wires going to the pull chain switch .. you can replace the capacitor box .. and you can replace the 3 or 4 position switch ... or you can remove all that stuff and put in a remote controled system .. that involves a box that just fits inside the fan .. it is hooked to AC power and neutral .. it then hooks up to the lilght and the fan giving you control over both .. you can vary brightness and fan speed .. you would no longer need the fan or light pull switch or the capacitors ... you could also get a new fan having such a controller .. since yours is fairly old it might be worthwhile to upgrade .. some of the remote controls allow you to set a temperature ..if the room goes above that temp then the fan turns on automatically and the speed is determined by how much higher the room temprature is from that set value .. some remotes also give you an additional very low fan speed .. thats nice at night when you just need a gentle breeze .. some also allow you to set a delay before the lights go out after you have clicked "turn off" ... that gives you time to exit the room or get in bed before the lights actually go out ... kindof nice features that might make it worth while to up grade .. to get parts for your old fan see this URL
since Home Depot sells hampton bay .. then they might have parts as well .. worth a try .. you can also see new models there ..
Jun 06, 2010 | Hampton Bay 52 In. White Redington...
Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
May 17, 2010 | Westinghouse Electric Westinghouse...
Want to install Fan and light control from one switch.
'define control'
anyway, that all the lights work together makes it simpler
most fanlights, updated by homeowners replace a lamp only unit, with on/off provided at the switch, and cable pulls on the unit to change speed direction of the fan
my favorite is paired dimmer switches, giving control separately of light and fan speed, fan direction still changes on the pull switch, requires 3 wires in the switch box, (power and 2 switched lines), to the lamp connector and fan motor connector, any sparky can pull the extra line with fishtape along the existing cable run. easy peasey.
Really good electricians pull three wire to light circuits, when the house is built or reno-ed. but you know how oftern that is gonna happen, 3 wire costs 3c more per foot, if there is 3 wire in the switch box -your home and hosed
or just for speed/dimmer control a dimmer switch can replace the existing single switch. but you still have to pull the cords to start the fans
its easy, with the caveat that you may kill yourself, or someone else, or burn the house down, if you dont do it right
Sep 26, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
Leviton (102-5G108-RW5) Logo
52 people viewed this question
Top Leviton Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
