Question about T-Mobile MDA
MDA will not power up.
I charged my MDA all night as usual when my battery is low.  I talked on it during my drive to work the next morning. Turned if off once I got to work as usual. Tried to turn it back on about 1 hour later and nothing happened. I just will not power on anymore! It is only 18 months old. Any suggestions?
Thanks, Ness7386@comcast.net
  • Ness7386 Mar 17, 2008
    I called HTC customer service to find out what they could do for my MDA.  I was advised that I could pay for the shipping to them but I would have to provide them with a credit card number to bill the charges up to $200. But that it may not cost that much depending on what they found to be wrong with it. If I chose not to have them repair it, I would have to pay for them to ship it back to me.  Instead, just after posting this comment, I opened my MDA back cover dusted off the metal contacts on the battery and inside the MDA itself.  It didn't appear to be dirty, I just didn't know what else to try.  Then I plugged in the AC adapter and jiggled it around a little.  I almost couldn't believe my eyes when I saw the red light appear indicating that the phone was charging.  I let it charge until the light turned green and voila! My MDA is working again.  I guess it just need a few weeks rest.  I have no idea why it stopped working or what made it start working again.  Good luck to you all.
Another this to try is get a new battery.
mine had the same problem i would try to charge and nothing and it would turn on for about 30 seconds then turn off and i tried putting it on a charger within those 30 seconds but it wouldnt take a charge.
i got a new battery theat had some charge in it and it worked great! alot of the time thats all you need it a new battery
Posted on Mar 30, 2008
Crank sensor
During the night or after the car sets for a while. The battery voltage will drop from the normal 13.6 to 13.8 volts when running and Charging, to between 12.3 to 12.6 volts. If the Crank Sensor is going bad, it may not operate correctly with the lower voltage. Check your Battery Voltage in the morning with a Volt Meter. If the Battery Voltage is lower than about 12.3 to 12.5 volts. You may need a new battery. Try leaving the battery on a low current Battery Maintainer overnight and see if it starts in the morning. I have seen many cars that shut down with Low Battery Voltage. Darn these New Fangled Cars and their Computers! FYI, we have never seen a Crank Sensor fail in this manner..... Check the RESTING Battery Voltage.
Aug 17, 2014 | 2001 Dodge Stratus
ELECTRICAL ISSUE IN SUBURBAN
if the bridge (three diode that turn AC current to DC in alternator) is bad it causes internal draw
Jun 19, 2014 | Chevrolet Blazer Cars & Trucks
2004 Ford Taurus, problem started last night. Drove to store, came home & parked. Tried to restart to park closer to curb and would not start. Engine did not turn over. Got low oil pressure message,...
Well your vehicle is indicating a problem, did you or your husband check the oil quantity? If it is low replenish the quantity. Also your battery seems to be failing, when you park it for a long time it will gain a little bit of power, thus when you come outside in the morning it would be better off then if you turned off the car and ran into the gas station to refuel and tried to take off. This shouldn't be a problem if your alternator is working properly and charging the vehicle while you drive. You may want to have your husband remove it and bench test it at a Checkers/Autozone or a local auto parts facility.
If you have more details, or questions email me at
xxsodasipperxx@yahoo.com
Dec 17, 2009 | Ford Taurus Cars & Trucks
I charged my phone one night and the next morning it wouldn't power on. Until this point it worked fine. I always turned it off when I charge it at night. I swapped batteries with my wife's Duo but it...
Have you off the charger........?? If you have not, due to excessive consumption of charge, It has been damaged. Take it to a authorized dealer.
Aug 15, 2009 | Cell Phones
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
Battery dies really fast
change power setting or get a new battery
May 29, 2009 | LG Vu CU920 Cellular Phone
My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
Apr 07, 2009 | T-Mobile MDA
I have an T-Mobile MDA. I haven't used it for over 6 months, went to charge it last night. plugged in the charger and the blue power light came on, went to menu screen. Left the MDA charging upon returning...
Your first bet is to remove the battery and hold down the power button for 10 seconds, then replace the battery and try to turn it on.
Sorry I'm not more familiar with the model of phone you're talking about but this has worked for my old PDA's when they won't power-cycle correctly.
Jun 27, 2008 | T-Mobile Computers & Internet
Help ASAP my MDA wont turn on
it might take a while tfor the light to come on . leaving it on all night should not hurt it. try charging it again
Nov 06, 2007 | T-Mobile MDA
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
T-Mobile MDA Logo
118 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
