Question about Nikon COOLPIX S200 Digital Camera
Memory card won't stay in
When I push the memory card into the camera, it "clicks" but won't stay seated. It always pops out. It is still functional, but a pain. Thanks - Dave
  • Anonymous Dec 28, 2008
    I have had the same problem with memory card popping out regularly since I got this camera. Now it won't stay in at all. I'm so mad that I didn't send it back right away and try to get a refund when it was new. I thought it was just an annoyance that I could handle by clicking it back in when it pops out..... no more.
  • davidpaolazz Dec 28, 2008
    I have the same problem. It used to stay in, but now it pops out all the time. Help.
    Scholar:
  • 154 Answers
Dear dave how did you insert the memory ? it will only work in one way , the other way the memory card may be seated but infact it is not fully seated and won't want to goe further , Take out the memory card turn it around so that the label side is facing the other way and try to see if ti will fit in that way you wont have to push it hard just once light and than it will have to be in place
Posted on Apr 29, 2008
My memory card will not stay down in my Kodak easy share z950 how can i fix it so it will stay down
There is a little spring assembly in there that pops the card out when you press a button or something. But if the button is stuck or not working the card will always pop out! If you remove the spring that will do the trick - to remove card in future you use tweezers like I do with my Garmin! Does the trick and works fine!!!!!!!!!!
Mar 07, 2016 | Kodak EasyShare Cameras
My vivicam x024 won't turn on. how do i remove the memory card? will the photos still be on the card if I remove it?
The SD memory card slot in located on the side og your camera. Push the SD card and it will pop out.
The photos are stored on the SD memory and removing it from the camera will not lose the photos stored on this SD memory card.
Remove the memory card from the camera and insert it into anUSB memory card reader. Connect this USB memory card reader and memory cardinto the USB port of your working computer. Your computer will see this as anUSB Mass Storage Device or an external storage device; you can then open thefolder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 28, 2012 | Vivitar ViviCam 5100 Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Camera won't register that there is a memory card, always saving pics to internal memory
Did you use a high capacity memory card with an old camera? For example, did you use a SDHC card in a somewhat old camera?
Some cameras accept only SD card. Although SDHC card has the same shape, it won't be reconized by the camera.
Sep 23, 2011 | Cameras
How do I take out the memory card?
Hello there,
You should push the card down to eject itself up. Then just pull it out from the compartment.
Hope this helps. Please let me know. THank you for using FixYa.
Jan 23, 2011 | Casio EXILIM EXS7 Digital Camera
How to delete images off a sandisk extreme 3 2.0gb compact flash%3F
Pop your memory card into your card reader, wait about 15 secs and it will appear on your computer as a drive. Double click on this drive and you will see either a lot of icons corresponding to the photos on the card or a lot of thumbnail pictures of the photos. Again right click on the drive and click on select all on the popup box. When all the icons or thumbnails are highlighted left click on them and the click on delete on the next popup box. Whatever you do DON'T try to format the card with your computer. If you want to format a memory card for a camera always use the camera's format function to do so.
By the way, the photos can also be removed by using the delete function in your camera's menu display.
Make sure the record inhibit tab on the memory crd isn't activated. If it is you won't be able to delete anything.
Apr 21, 2010 | SanDisk Extreme III 2GB Secure Digital...
My memory card keeps popping out!
on the side of the door panel that it goes into is a lil tiny hinge with a small piece of plastic that prevents it from popping out,i do believe your lil door may have broken off or your hinge is bad...
Jan 31, 2010 | Samsung Behold Cell Phone
Make sure you push in firmly untill it clicks . Make sure its an SD card Too.
Jul 05, 2009 | Nikon COOLPIX L18 Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
Memory card will not "stay clicked into camera". Was working fine. Took memory card out - now it will slide in, but not click into place - keeps poppin gout.
i had a similar problem with a canon once, some cards have to be pushed in very hard, (not fast, just hard) it seems like it cant go, but push very hard and it should click in
Sep 21, 2008 | Canon PowerShot A610 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
242 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
