HP 4350 ERROR MESSAGE: 49.2F90
WHEN I INSTALL THE DUPLEXER IT WILL PRINT SEVERAL MESSAGES, THEN STOP AND GIVES ME THIS MESSAGE.
WHAT DOES IT MEAN AND HOW DO I FIX?
DAVID BROOKS
cpapactax@cs.com
  • 19,396 Answers
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Posted on Mar 15, 2008
  • Ginko
    Ginko Mar 15, 2008
    In the specific Error 49.2F90 is due to a bug in HP firmware. The printer goes on error 49.2F90 when processing file with bad data ..
    Try disconnecting the printer from power outlet and connecting it back. Try also the general reset procedure above.
    If the error message persists you may need to take printer to service center to reinstall firmware.
  • Ginko
    Ginko Mar 15, 2008
    In latest firmware upgade bulletin HP says "Corrected situations where a 49.2F90 and 49.2F9C errors
    would
    occur when using
    Secure Fast Erase and Santitize Erase."
    The problem is usually corrected resetting the printer .
    If you need to upgrade firmware here is download page.
    Firmware versions can be upgraded remotely using HP Web JetAdmin. Click to download
    Regards
2 Suggested Answers
printech
  • 159 Answers
SOURCE: HP 4350 ERROR MESSAGE: 49.2F90
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Posted on Mar 16, 2008
Hp 4350 printer memery error
Hi guyfr,
This means that the printer is unable to read the electronic information (e-label) on the print cartridge so that the printer can keep track of the page count for the print cartridge.To resolve the issue:
  1. Open the top cover and remove the print cartridge. Then, reinstall it.
  2. This is typically an e-label issue. The printer will continue to print after pressing the green SELECT button. The consumable management features will be lost (such as the gas gauge, cartridge page count, estimated pages remaining, etcetera) and the control panel may report that the printer has a non-HP print cartridge installed; however, the product will continue to print without problem until the toner runs out and the pages begin to fade, then the print cartridge may be replaced as usual.
  3. If this workaround is not acceptable or the error message persists after performing all of the recommended actions, contact an authorized HP Service or Support Provider: http://www.hp.com/go/support
Hope this helps.
Thank you for using FixYa.
Nov 01, 2010 | HP LaserJet 4350 Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
Have a hp laserjet 4350 network printer and have select print on both sides check on the printer preferences and in the finisher tabs. but still doesnt not print on both sides.
This would have to be a 4350DN or DTN model to do automatic duplexing. I would make sure you have one of these 2 models. Depending on what driver was loaded the duplex option may show up, but if the printer does not have the duplex option and the associated firmware then it will not duplex automatically.
This is the only thing I have seen that would cause what you are describing.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 30, 2010 | HP LaserJet 4350 Printer
I have a 49.5001 service error on a HP 4350 laserjet printer. Any suggestions?
X PRINTER ERROR A firmware error occurred 1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
This error is usually caused by a bad formatter board
Apr 05, 2010 | HP LaserJet 4350 Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Printer error messsage
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
Jan 16, 2009 | HP LaserJet 4350 Printer
Error message
My printing stops and I get this error message Error-0x07a74dd6 1959:lib_barracu.
What is the meaning to this and how can I fix the problem?
Mar 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Action :
Mar 15, 2008 | HP LaserJet 4350 Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
Printer displaying 49.2F80 error message
Network data corrupted or print job corrupted
Jun 07, 2006 | HP LaserJet 4350 Printer
1,593 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
