Question about HP LaserJet 4350 Printer
HP 4350 ERROR MESSAGE: 49.2F90
WHEN I INSTALL THE DUPLEXER IT WILL PRINTER SEVERAL PAGES AND THEN STOP AND SHOWS THIS ERROR MESSAGE- 49.2F90. WHAT DOES THIS MEAN AND HOW CAN I FIX.
DAVID BROOKS CPA
cpapactax@cs.com
  • boyercpa Dec 10, 2008
    Duplex printing on 4250 no par cable connection on my computer only USB, it only happens with a specific virtual program. Even happened infrequently before the duplexer.
  • Anonymous Mar 19, 2009
    ERROR 49 2F90 WHAT IS THIS
    New Friend:
  • 159 Answers
He printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Posted on Mar 16, 2008
"the printing operation has been aborted.
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
I have an hp 4300 with a 13.12.00 error when the duplexer is installed
Here is a copy of the 13.12 error troubleshooting steps from the service manual.
1. Press the HELP ( ) button for
detailed information about
clearing the jam.
2. Press the UP ARROW( )
button and the
DOWN ARROW ( ) button to
step through the instructions.
3. Check the paper width and
fuser delivery sensors
(PS106, PS108) and verify
that the sensor arms move
freely. (See "Location of
printer switches and sensors"
on page 336.)
4. Check the inside of the
duplexer for scraps of media
that might have torn off when
a jam was cleared.
5. Replace the media-size
sensor (PS106) and fuser.
See "Location of printer
switches and sensors" on
page 336 and "Fuser" on
page 162.
6. Turn the power off. Remove
the duplexer and turn the
power on. If the error
message persists, replace
the DC controller PCA. See
"DC controller PCA" on
page 181.
7. Replace the fuser (PS108).
See "Fuser" on page 162.
8. If the error message appears
frequently, see "Paper-path
troubleshooting" on
page 295.
Feb 07, 2013 | HP LaserJet 2420 Printer
Hp 4350 printer memery error
Hi guyfr,
This means that the printer is unable to read the electronic information (e-label) on the print cartridge so that the printer can keep track of the page count for the print cartridge.To resolve the issue:
  1. Open the top cover and remove the print cartridge. Then, reinstall it.
  2. This is typically an e-label issue. The printer will continue to print after pressing the green SELECT button. The consumable management features will be lost (such as the gas gauge, cartridge page count, estimated pages remaining, etcetera) and the control panel may report that the printer has a non-HP print cartridge installed; however, the product will continue to print without problem until the toner runs out and the pages begin to fade, then the print cartridge may be replaced as usual.
  3. If this workaround is not acceptable or the error message persists after performing all of the recommended actions, contact an authorized HP Service or Support Provider: http://www.hp.com/go/support
Hope this helps.
Thank you for using FixYa.
Nov 01, 2010 | HP LaserJet 4350 Printer
Have a hp laserjet 4350 network printer and have select print on both sides check on the printer preferences and in the finisher tabs. but still doesnt not print on both sides.
This would have to be a 4350DN or DTN model to do automatic duplexing. I would make sure you have one of these 2 models. Depending on what driver was loaded the duplex option may show up, but if the printer does not have the duplex option and the associated firmware then it will not duplex automatically.
This is the only thing I have seen that would cause what you are describing.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 30, 2010 | HP LaserJet 4350 Printer
HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Mar 20, 2008 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
2,762 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
