Question about Philips HTS3400/37 System
RE: Needs the IC # for Location 902
Hi, i am a tech and i have this HTS system to be repaired..the top of the IC in the power stage is blown off clean. IC location is 902...what i would like help with is to identify the # that belong to the top of that IC..
thank you, Lennox
  • Leroy Lewis
    Leroy Lewis Mar 25, 2008
    Thanks a million Avid Imps for your help on finding the correct IC it was the exact one but as i install it in the board and plug it back in there it goes again. i have check all the parts in the power stage, they all seems to be reading fine so i gave up...HELP
  • Leroy Lewis
    Leroy Lewis Mar 28, 2008
    Hi Avid_Imps,
    Here is my e-mail address (swtguy2005@yahoo.com)
    thank you for your help.
    Lennox
  • 476 Answers
According to the service manual:
IC902 9965 000 29296 IC 8P FSDM0365RN DIP
Posted on Mar 17, 2008
  • 1 more comment
  • David Simpson Mar 27, 2008
    Leave your e-mail address, and I'll send you the service info I have.
  • Roland Graf
    Roland Graf Jul 14, 2014
    Hello. I also would like help with to identify the # that belong to the top of that IC 902. It is a Philips HTS337. Or maybe an eqvivalent to this. Thank you in advance. Roland. rolle_g2003@yahoo.se
  • Roland Graf
    I mean HTS 3357
Fender Passport pro 500 - speaker static temporary, then goes away. Usually occurs shortly after turning system on.
If this system is still under warranty get it to a warranty service center. This is an early stage symptom of failure with the Power Amp IC. Fender has a good warranty policy on this stuff - 1 to 3 years
If not under warranty you may want to wait until it the problem is more persistent - easier for a tech to fix - unless it IS every time right now. A good tech can identify the issue quickly once "on the bench". My 'gut' feeling is the Power Amp IC when the system is first energizing to full stable power.
Oct 26, 2013 | Fender Passport Deluxe 500watt Sound...
I can't turn on
The circuit is blown a couple of the connectors crossed. It is going in protect mode to keep it from further damaging the internal electronics. Open it up and double check all connections.But if you don't have any idea how to check it then i suggest you to take it for a repair,the cost will be between $100-$150.
You have to get it serviced and replace whatever has blown up inside and after that you won't get the protected message again.
Goodluck..
Feb 14, 2008 | JVC HX-D7 Shelf System
Tip
Stuck in Progressive Scan? Can hear movie but Can't see Video?
Here's the scenario:
All cables hooked up correctly.
System is stuck in Progressive scan (P-SCAN on display viewer)
SITUATION:  You can hear the movie playing, and you are certain all connections are correct.  Your Television may not support Progressive Scan Video so all you hear is the Audio Track.  Here's what to do.
SOLUTION:
Step 1: Remove DVD from player.
Step 2: Unplug from power source for 20-30 seconds, plug back into outlet.
Step 3: You need to press two buttons at the exact same time.
Step 3a: Prepare to press #1 on your HTS remote
Step 3b: Prepare to press OPEN/CLOSE button on your HTS.
Step 4: Press both OPEN/CLOSE button and #1 on your remote at the same time and HOLD until P-SCAN on your HTS display turns off. Should take no more then 20 seconds max.
Step 5: Repeat all if human error occured and no improvement. Or call 1-888-PHILIPS for HTS tech support
Enjoy!
NOTE: This solution was given to me by Philips Tech Support Division when I encountered same issue.
on Sep 11, 2007 | Philips HTS3400/37 System
Power Supply for Philips HTS-3261
My Philips 3261/98 Power Module Dead also, I replaced on IC on the power PCB, can work already
Jul 02, 2013 | Philips Audio Players & Recorders
From what i reseached my problem and it sounds like i may have a blown power surge. my tv won't turn on /power up, the stand by light flashes 6 times.
Thats horizontal problem.check C515 and 516 and the jungle IC....IC 206 those are your problem.if you are not a tech then have a tech repair your tv.good luck.
Sep 17, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound clarity not good beause distrubing sound
It depends on how the sound is heard, if the sound is distorted then the amplifier section must be checked, It can be fault in the power output IC, fault of the bias or fault in the pre- amp section.
Secondly if the sound is jarring then the speakers needs to be checked, it can be problems on the diaphragms or coils.
You will also need to check or switch source of sound to confirm if this was from a source.
Also an AF signal test and injection will confirm the stage that is effected.
Jul 12, 2011 | Philips HTS 3154 Theater System
Hi. We're having power outages in TX right now. When power in house came back on, our Philips Home Theatre System (HTS 3544) seems to have lost all its power. We've plugged and unplugged the unit, and...
These are prone to power spikes...and for that reason have a fuse located on the power supply board...known as fast blow fuses...which are glass and easy to see if they have blown..sometimes all you need to do is replace the fuse on the rear of the unit if you can locate a fuse cap...just unscrew and replace....Always unplug televisions and audio equipment and routers during power outages and thunderstorms as a preventative to blowing psu panels on electrical devices connection to your house mains for this reason .
Feb 05, 2018 | Philips HTS3544/37 Theater System
The power supply, LCP106830-0001 is bad. I need a schematic for Philips HTS-3555/37 and new poser supply to repair.
You won't get voltage if you completely disconnect the lcp106830 power supply from the board. The connection to the front panel is required and is used as feedback. I just repaired one and found one of the power diodes faulty.
Dec 20, 2010 | Philips HTS-3555 System
Hi I accidentaly actiivate the child control on my tv and turned it off, I don't have the original remote any longer and I can not turn on my tv. Please help Mike
Concerning the problem...it is extremely likely that you have a corrupt EEPROM. A very common problem with this TV.The correct EEPROM (IC location IC 002) is dependent on which microprocessor (IC location IC001) and which stereo decoder (IC location IC 1001) are present on the board being repaired. Take this info to a TV tech and they will find the correct EEPROM to replace. Your TV will come back to life. If not, give me the numbers of ICs IC001 and IC1001. I will forward the correct EEPROM part #. Then the tech will repair your TV. Thanks for asking and show all hands of support!
Dec 01, 2010 | Philips Magnavox 27MS343S 27" TV
Phillips 6500 home theater system
Turn the power off, and then unplug the home theater from the wall outlet. Plug it back in after about 30 seconds, and turn it back on. If it still won't eject, then the HTS needs repair. Philips will replace it if it is still in warranty.
Feb 23, 2008 | Philips HTS-6500/37 System
Philips HTS3400/37 System Logo
250 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
