Question about Maytag 24 in. MDBH955AW Built-in Dishwasher
Just not cleaning
I am a stickler about loading my dishwasher properly but even so it seems to leave a grainy sand like residue on many of the dishes like it is not getting rid of the dirty water between cycles the dishes constantly seem to have a what looks like a cream of wheat substance on them and we don't eat cream of wheat. I have disassembled the plastic water supply arm and the water jet arms attached to it (not sure of the technical names) and found heavy deposits of this wheatena like substance to clean out. Each time I hope the dishes will come out clean but they never do. I use a gell cleaner in the unit.
  • carole685 Oct 18, 2008
    Same issue - have tried the vinegar and also dishwashwer magic. Even when all the dishes rinsed prior to loading, there is a sandy residue left - particularly on inside of glasses on top shelf.
  • celestecards Dec 05, 2008
    We have tried the above but still problems. Could it be that the pump is clogged and how do we fix that?
  • 770 Answers
Run a cycle thru with no dishes and 2 cups of vingar this will flush out the unit then run a normal load should be ok let me know THERE also is a product called dishwasher magic you can run that thru as well but the vingar is cheaper
Posted on Mar 15, 2008
6ya staff
SOURCE:
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Ge Triton dishwasher GSD5500GOOWW was not cleaning like it used to- I cleaned screens at back bottom-very dirty- also-detergent cup stuck opne - took door apart and got it unstuck - it works fine now. - it...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dish washer does not clean dishes very well and leaves a grainy residue stuck to dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Nov 30, 2010 | Bosch Evolution 500 SHE45M06UC Built-in...
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Dishes not getting completely cleaned.
heatman101
Apr 28, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Not washing properly.fills and water circulates but does not always dissolve all of tablet and does not clean both top and bottom shelves. checked arms clear. What next?
There is not enough salt in the dishwasher & that is what causes the sand like residue on dishes. Sometimes even when you use an all in 1 dishwasher tablet this may still not contain enough salt for the hardness of the water in your area. Using salt regular helps keep the dishwasher clean. The problem is hard water going into your dishwasher. it leaves the residue you are talking about. There is a new affordable product called the dishwasher filtration system it filters out the hard minerals that cause this before they enter your dishwasher leaving your dishes spot free with every load. You can get it at www.dishwasherfilter.com.
Thanks for contacting fixya.com
Nov 24, 2009 | Bosch 24 in. SGS43C12 Classixx...
My Bosch shu 42 just stopped cleaning. there is soap residue also on the dishes. It doesn't seem to be getting really hot water. We cleaned the filter and made sure it was loaded correctly.
When the heating element fails on dishwashers, the wash cycle water can not be heated high enough the activate the DW detergent powder.
Replacing the heating element should fix you right up.
Also, resist the temptation to switch the a cheap, generic powder. A brand name e.g. Electrosol or Cascade powder is proven to work well. The ultra-cheap powder will leave white patches on the dishes and it will not dissolve completely, even when the heating element is working properly.
Good Luck!
May 04, 2009 | Dishwashers
Our GE dishwasher does not seem to be rinseing the dishes very well, can you help? thank you
many things can cause washabilty issues: check drain line for high loop it should not go down right out of the garbage disposal it should go up first, too much soap and too clean of dishes at the beginning leaves soap residue,if you clean or rinse the dishes well before you even load them back way off on the soap.
Apr 25, 2008 | Dishwashers
Dishwasher
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
Nov 05, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
271 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
