Question about Car Audio & Video
How do I know what speakers fit my car? I have a 2007 saab 9-3 convert I don't know the size of my front and back speakers. I keep hearing various sizes 6.5 for the fronts and 5.25 for the back, I've also heard 3.25 for the back. I've been told to look at Boston Acoustics Brand maybe the component kind 75- 90 RMS. Please Help! How would these do? BOSTON ACOUSTICS PRO60 6.5 CAR AUDIO COMPONENT SPEAKERS
  • solovly Mar 17, 2008
    crutchfield doesn't tell me info on the 07 9-3 convt, thanks.
Yeah, I did that already. They didn't know either... All they knew if I blew a speaker they would just order the same one that came w/ the car. Thanks for trying.
Posted on Mar 18, 2008
    Sergeant:
  • 300 Answers
The very easiest way to check is to click this link to go to the "Outfit My Car" section of Crutchfield.com. They will tell you exactly what size speakers the car came with.
Posted on Mar 17, 2008
  • Tygh Duval
    Tygh Duval Mar 18, 2008
    Wow! That's the first time I've seen Crutchfield have no data on a car. Well, there's a very small chance that calling Crutchfield will get you a different answer. Another option is to call your local Saab dealer (with your VIN handy) and they should be able to tell you what size they are. Sorry I couldn't be more help!
SOURCE:
My alarm keeps randomly going off. How do I disable the car alarm? thank you
Alarm siren is fitted under left hand front wing(fender) requires removal of wheel and underwing splash shield to gain access. No longer available from saab uk but can be repaired.New rechargeable batteries and the three capacitors are available (E-Bay) or a firm in Wales will recondition.(E-Bay)
Apr 19, 2015 | 2007 Saab 9-3 2.0T
Can I tow a 2007 9-3 on a dolly behind rv?
Front wheel drive, front tires off the ground, Yes. All wheel drive, you have to pull the rear drive shaft. Rear wheel drive, you should pull the drive shaft. But you can pull it with the car in neutral.
Feb 14, 2015 | 2007 Saab 9-3 Aero Convertible
2000 saab 9 3 runs perfect then shuts down
It is possible the rim from a Saab 9-3 will fit a 2000 Saab 9 5, however it will depend on the wheel size. Often Saabs were sold and/or modified with various wheel sizes. ----------------------------------------------------------------------------------
Original Launch CResetter
Mar 06, 2013 | 2006 Saab 9-3 1.8i
Manual key wont unlock saab convertible 9-3 07
Possible door lock actuator. Or you have a mechanical failure in the mechanism. Id remove door panel and inspect the mechanism but if you dont know what to look for, take to a reputable shop
Dec 30, 2012 | 2007 Saab 9-3 Aero Convertible
2007 Saab Convertable, how to change driver side headlight?
How do I replace the left Xenon low beam bulb on my 2007 9-3 4dr 2.0 turbo SAAB?. The battery box , fuse box and windshield washer resivour practically a **** upto the back of the bulb area.
Do I have to remove the entire headlight assembly? if so will that ruin the auto light adjustment for the lowbeam.
Apr 23, 2009 | 2007 Saab 9-3 Aero Convertible
Saab convertible hood keeps jamming when taking down and putting
Could be 2 things...
THe nipple on the hood can be adjusted higher and lower to make a looser or tighter fit...
or the release cable can be tighted but a small clamp on the radiator core support check those 2 things first...
Mar 13, 2009 | 2001 Saab 9-3
Bluetooth
HI
There is a known fault with this. SAAB can fix the problem by replacxing the bluetooth unit with a modification.
Also, ask for the front screen pillaresto be foam filled, this improves the noise issue when using the bluetooth phone.
Dec 23, 2008 | 2007 Saab 9-3 Aero Convertible
I dont know what speakers fix my car
You can install anything these days if you have the right equipment. Use the original speakers as a gauge.
FRONT - 6" Component
BACK - 6 x 9
Jan 30, 2008 | Sony XPLOD CDX-GT200 CD Player
Car Audio & Video Logo
220 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
