Question about Pentax SF1n 35mm SLR Camera
Pentax SF1 Where can I take this camera to get it fixed. It seems like the film advancer has issues. It whines.
  • Anonymous Mar 19, 2009
    With fresh battery in SF1 nothing really works, the film will not advance to first frame, modes not changeable, only motor sound heard when shutter button is pressed but shutter does not trip nor fim moves. Just DX indexing works but not manual ISO input. Everything is stuck.
  • Anonymous Apr 05, 2009
    Exact same problem with my own SF1 film not advancing only buzzes. Have disassembled top gear apparatus found everything perfect with gears like new all mesh properly. My conclusion is that SF1 is out of sequence electronically because shutter will not trip. Camera wants to advance automatically to next frame but is halted by nonsequential shutter which must fire first to release gears that then wind up shutter for next shot. Might be electromagnet not releasing shutter blades due to faulty capacitor that gives electromagnet its trip charge or CPU not transmitting proper signal. Pentax no longer services this camera and private outfits are cost prohibitive. Best bet forget the SF1 keep as paper weight or souvenier for children to play with and get a digital SLR!
    Scholar:
  • 185 Answers
This model has a gear train from the motor to the advance sprocket. The gears are plastic and prone to strip. Try E-Bay for a reasonable replacement and keep this one for parts. There are no new parts available.
Posted on Dec 08, 2008
SOURCE:
Will lens from a sf1 fit the newer models like the Kr or better
Yes. The new digital model cameras will accept the older K-AF lenses.
Mar 01, 2013 | Pentax Sf1 35mm Slr Film Camera 35-70mm...
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
My pentax k1000 wont advance the film. How can I fix it?
First inspect the bottom of the camera, on the right side there should be the pin that you push in when you roll up the film. If it is not protruding while there is film inside then there is a issue with the mechanism.
If not then it may be an issue with the way the film is inserted. Is it a new problem or has it been an issue since you aquired the camera?
Feb 25, 2011 | Pentax K1000 35mm SLR Camera
Camera repairs
loading mechanism,gear system must be defective,so u r not able to load the film,while loading shutter gets charged,stops running,so the shutter mechnism also be chaqued.
Mar 06, 2010 | Pentax SF1n 35mm SLR Camera
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
Jun 08, 2009 | Pentax ME Super 35mm SLR Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Film advance lever stuck
The shutter parts are most likely broken. That is usually the tell-tale sign of a broken camera, not advancing. Repairs for film cameras are very expensive and if parts are needed, it may be impossible for a 20+ year old camera. My suggestion is to find a replacement film camera system. Your Ricoh lenses will fit on a Pentax camera, but not work in Auto Mode. Prices of used Pentax cameras with built in motor drives are around $100. Check on line cameras stores. They have lots of use cameras/lense. A lens to use on that is another $75 or so. Only Nikon and Canon make new film cameras anymore. If you want an indestructable K-mount, find a Pentax K1000. Many lenses are available but no motor drive nor auto exposure on that model.
Apr 09, 2008 | Ricoh KR-30SP 35mm SLR Camera
Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Feb 18, 2008 | Pentax ME Super 35mm SLR Camera
Pentax SF1n 35mm SLR Camera Logo
443 people viewed this question
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
