Question about Video Game Consoles & Games
Nintendo Wii Problem
Wii system. Video output suddenly quit. Audio still ocmes through. System powers up (button goes from red to green). When you hit "A" you can hear the opening screen come up. But not video.
It barfed
Posted on Mar 16, 2008
Chmy wii console or ACadaptor hve a problem,on console power button turns red but whenI press it to start it doesnt turn green but red light goes off what wrong with it?
Leave the wii unplugged overnight to remove any static electricity that might be interfering with the powering of the console.
If that does not work, try and follow nintendo's power troubleshooter: http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Jul 25, 2011 | Nintendo Wii Console
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
My power light turns yellow instead of red i have to hold thepower botten to make it red
With the Wii system, when you hit the power button, it goes into Standby mode. That is the yellow light. In standby mode, the system draws a little bit of power, and it will go into a ready to play state faster than when Off. Holding the power button FULLY powers off the Wii system, and that will give you the red light. Hope this helps!
Feb 27, 2011 | Video Game Consoles & Games
My Wii has a red light when plugged in, and a green one while turned, on, the problem is, nothing is displayed on the tv or heard, also, the disk drive whirrs for a few second after turning on. The tv...
If the light is red, it means WiiConnect24 is turned off. Green means the system is turned on and it's normal for the Wii to whirr a bit when it's initially turned on.
Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
That said, Nintendo recommends calling them if this doesn't fix your problem. Hope this helps.
Jan 06, 2011 | Nintendo Wii Console
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
I have Epson Projector and Acer Laptop both with DVI connections. How do I connect a Nintendo Wi-fit consul so I can play and hear the games. I have a wireless sensor.
I've never seen a projector with DVI ONLY -- double check your projector and all compartments and see if it has any other inputs. The wii can use the regular composite, red, yellow, white output. The wii can use SVideo and the Wii can use component output -- red, green, blue video and red/white audio. I do not think there is a DVI cable for the Wii.
Mar 09, 2010 | Nintendo Wii Console
Wii has no picture
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
256
Mar 18, 2009 | Nintendo Wii Console
Problem with wii
I did setting up and come up w/ Language--ENGLISH
and I hit confirm, nothing happen, it means the remote cannot talk w/ the Console, then I did the standard mode synchronization, still the same.
How to make the communition betwenn the console and the remote?? Charlie
Jul 05, 2008 | Nintendo Wii Console
Nintendo wii
Looks like you may have a brick. You could send it back to nintendo.
Jun 22, 2008 | Nintendo Wii Console
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
44 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
