Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
I HAVE WAVEY LINES ON MY TOSHIBA 42H83 RP TOO!
YEAH, I HAVE THE SAME WAVEY LINES.....TRIED ALL THE SIMPLE FIXES AND NOTHING HELPED. CALLING A PROFESSIONAL TO REPAIR......MY SET IS A LITTLE OVER 4 YEARS OLD.....CAN'T BELIEVE ITS GONE OUT......MY ZENITH SENTRY 27 IS ALMOST 10 YEARS OLD, BEEN MOVED, DROPPED AND MY DAUGHTER EVEN SPILLED MILK IN IT AND IT STILL WORKS FINE..........MY NEXT TV WON'T BE A TOSHIBA NO MATTER HOW GOOD THE DEAL IS....!!!!!!!
  • 1 more comment
  • kghit Jul 18, 2008
    My DVD picture is wavy as a result of the 42h82 video imputs failing. I'm told the tv is next to go. Is the hypermodule the problem?
  • glowbaby Mar 08, 2009
    The problem "used" to go away as the tv got warmer. HD signals from cable box are slightly wavy. Thru my ps3 I can only get 1080i to come in clear, everyother setting (and games not 1080i compatable) are unwatchable because screen is scrambled.
  • salute2u Mar 13, 2009
    I have the same problem that began to go away as the unit gets warmer. We replaced the signal processor and it still does it.
    Genius:
  • 1,030 Answers
Wavey lines all over screen? does piture inmprove when it get warmer? this to me is indication of the "hypermodule signal processor" this can be fix but s a difficult repair. have to replace several VERY SMALL capacitors not a repair for novice.
Posted on Mar 18, 2008
Wavey distorted screen
Ur tv convergence are dead.U must know how to solders?U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 02, 2010 | Toshiba 42H83 42" Rear Projection...
No Video
The VVPU14 hyper module in that unit is a trickey installation because they have their can tabs soldered to the motherboard and next to each of the solder points on the pad are fine wire traces on top and bottom of the board that can easily be broken or over soldered... Check there first, with a fine magnifier. To answer your question, no, there are no resets or anything else you need to do to after the H/M install. Good Luck. Bill
May 29, 2007 | Toshiba 42H83 42" Rear Projection...
Picture is distorted on my toshiba 42h83 audio is perfect. started with this problem slowly and was able to correct by switching between tv/video selections. Now picture is distorted all the time.
Distorted in what way WAVEY? there is a problem in the past with 11 very small capacitors that can cause this did it help when it warmed up? The trouble is these capactors can be replaced. but it take someone whe can do very difficult solder called surface mount. i do maybe 2 a month its very labor intensive i am not saying this is the prblem but this set does have that history
Dec 10, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba Convergence
You have one or more bad convergence amplifiers. Best to replace both convergence output ICs as well as check low value resistors associated with them.
Oct 16, 2009 | Toshiba 42H83 42" Rear Projection...
I have a toshiba big screen with three bulbs and the picture has wavey lines on the screen. Does this mean tubes are going out?
Most of these Toshiba sets have a "hyper board" that processes all the signal and a lot of them are going bad---lots of surface mounted filter caps on the board dry out and usually it begins that lines in the picture and after several minutes the problem slowly clears up and or goes away---as time goes on it takes longer and longer for it to go away----For most of these sets the only way to repair is remove the board and send it out for rebuild--rebuild of the board and labor may be more then the TV set is worth.
Jul 10, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 model projection HD tv has a bad wavy picture.
yes it can be fixed call a repairman and have them come out and repair it.it shouldnt cost more than a couple of hundred dollars to fix
Feb 01, 2009 | Toshiba 42H83 42" Rear Projection...
How to fix convergence problem on Toshiba TV Model 42H83
go to the site for your laptop
you can download a manual there
Dec 15, 2008 | Computers & Internet
Problems witha toshiba rear projection 2002 50h71 model
sounds like you might have the hypermodule capacitor problem. there is a cuircit board in this set that has 11 very very small capacitors that go bad this is charistic of wavey lines that go away after warming up. and eventally not going away. we repair about 2 of these a month at our shop. we would loved to just replace the board but this board is not availble we cant find it. so we very carefully resolder these caps. with magnifers and twezzers. so i dont recomend anybody attempt this except experience technician., you can easly damage this board and once damaged u cant find the board.
Oct 21, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 Touch Focus Problem
I just got finished repairing the same model . The convergence modules are bad cost of repair is 250.00 for a service center to fix. My advice would be call your local service center tell them what i told you bad convergence ic and ask them how much they charge,
thanks doctor video good luck since 1987
Jun 14, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
409 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
