Broken HP Pavillon dV6000
My pavillon dV6000 has endured a hit and the hard drive is now making a noise and the laptop will not turn on. What can i do? please help!
    President:
  • 2,351 Answers
Explain, (endured a hit). Electrical or physical?
For the hard drive (a clicking sound means a spindle problem). Suggest you get a new drive if it's no longer under warranty. Once you install a new drive you can slave your old bad drive into the system & pull your data off it before it stops working.
As for the laptop it's better off with a pro.
Posted on Mar 15, 2008
SOURCE:
Does the 2005 hp pavillon have a web cam?
Skype don't need a webcam to connect (i use skype and don't have a webcam).
Normally on a laptop you see it well on the upside of the screen
May 21, 2014 | HP Pavilion Computers & Internet
How do i change the language from spanish to english on a hp pavillon dv6000
Go into the Control Panel and look for Clock,Language and Regional settings. You should be able to do it from there. I assume that the version of Windows is either Vista or Win7.
Jun 21, 2012 | HP Pavilion dv6000z Notebook
Boot hp pavillon zd8000 with usb not possible?
Boot hp pavillon zd8000 with usb is possible.simply plug the USB flash drive with iso and reboot, then press F10 navigeyt Boot Order Mark hard drive, hit enter, Highlight your usb and press F6 so usb was on top of the press F10
May 15, 2012 | HP Pavilion zd8000 Notebook
MY hp pavillon dv6000 won't turn on. I press the power button and the blue lights turn on but they turn off at the same second,not even the fan turns on. PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Pavilion dv6000z Notebook
How do i turn on my internal mic hp pavillon 6000
Go to START->CONTROL PANEL->SOUND
Click on the RECORDING tab, click on the mic that you want to use. Click on the SET DEFAULT button.
Done.
Apr 22, 2010 | HP Pavilion dv1000 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Why isnt my hp g60 touchpad working keeps disconecting
My HP Pavillon dv6000 touchpad keeps disabling itself, randomly. I have to keep enabling it, any solutions?
Sep 24, 2009 | HP Pavilion G60-120US NoteBook
Hp pavillon zd open case
try checking if there are plastic locks that prevents from opening the case of your laptop. It may somehow be located on the side or the bottom of the laptop.
Attention: Dont force it to open it may break the lock..
Aug 07, 2009 | Computers & Internet
HP pavillon dv6000 boot troubleshooting !
First take out the battery, and run it on AC power alone , if it runs ok its the battery that has died, it you still can run the laptop with orw/o a bttery then the internal power supply has died.
Jul 12, 2009 | HP Pavilion dv6000z PC Notebook
Drivers for my pavillon tx1000
hi
i would like to provide you the drivers link. please select the correct model number and enjoy the free download.
Thanks
Appreciate to rate as "fixya"
Apr 23, 2009 | Computers & Internet
Open Questions:
Computers & Internet Logo
95 people viewed this question
Ekse
Alun Cox
