Question about Toshiba 40H80 40" Rear Projection Television
Toshiba 40pw8db with colored lines horizontally
Hi there hope you can help me please i have a toshiba 40ins projection tv i turn it on its ok then every so often the screen will get colored lines through the screen horizontally then i will turn it off and back on then its ok till it does it again
    Problem Solver:
  • 6 Answers
There are some boards in the tv that plug in (push down) have the power off and unplugged have a look around, and see if any boards have come loose, stay away from any thick red wires (EHT) DO NOT PULL At the Gray Rubber Caps that go to each gun (tube) RED GREEN Blue, this can carry a heavey charge even if the tv is off and has been for days, regards mark
Posted on Apr 08, 2008
  • mark smith Apr 08, 2008
    i have a toshiba RPTV it has sound, it has tube heaters, no sign of a picture at all from any colour gun (tube) the red light on the front stays red, not sure if it should go green, tv was naff when i got it. it has EHT any ideas on whats at fault. Anyone? regards mark
    40PW8DB FOROT TO SAY WHAT MODLE.
Colored lines down the tv
old tv. don't put anymore money in it. get you a nice flat screen. not work it being a projection. jmo
Oct 08, 2014 | Toshiba 42H81 42" Rear Projection...
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
Colored lines across TV
what this sounds like is that you may have a cable in the wrong part of the tv like maybe a vcr or audio cable check your inputs in the back of your tv that sounds like it what it might be i have a big screen tv and if i have a cable in the wrong part it will hiss and have lines on it too i hope this can help if not reply to me at Jonk3y @aol.com
Sep 23, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Can not align color dirvertions on test screen
I think you need a remote to use the convergence features of this set. Does it have an auto convergence feature? And does it work?
Dec 31, 2007 | Toshiba 55H70 55" Rear Projection...
Red and green colors won't allign....
There is one way. Get way to go in to service menu and set conversions manualy. Remember to save. Tv will be ok
Dec 25, 2007 | Toshiba 46HM95 46" HDTV
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 42PW33Q rear projection gone blue
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
  7. NOTE: IF the color stays stable, then you problem is resolved and you do not need to replace it.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Nov 18, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Touch Screen Error
RED GUN OK, you need convergence IC's replaced = Toshiba
part # STK392-110T.....................................T.
Nov 14, 2007 | Toshiba 50H82 50" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
