Question about GPS
My garmin c340, only a few months old just died--cannot get it to turn on and it definitely is not the fuse. Help!!
  • lostonexl Mar 31, 2008
    I have the same problem with my tomtom one xl. I shut the engine off and started it again. Afterwards, the device wouldn't power up. Is it damaged or is it the antitheft
I took the faceplate off very gently starting under "garmin". I plugged it into the cig lighter in my car and turned my car on. I pressed the reset button and it turned on (THANK GOD!!). I then let it charge a little.
Posted on Mar 16, 2008
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin trouble
Is your battery properly charged?Try replacing it with a new battery iam sure this will fix it.
May 10, 2008 | Garmin StreetPilot c340 GPS Receiver
H ow do i reset my garmin street pilot c340
To reset the Garmin C340 you will need to pull the Bezel off that goes around the screen. There is a reset button under there. Make sure that is what you really want to do before you do it.
Harleyknut
Mar 30, 2009 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not come on even when plugged in
I had this problem before, i called garmin and they told me that the charger cradle was not design properly so it sometimes doesnt charge...anyways...carefully remove the grey cover around touchscreen and there is a master reset which will set it back to factory...it worked for me...good luck!
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 turns on then shuts off even when plugged in
I have the same problem. I have had it for only 4 months.
Jun 23, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 went black and can't get it working
The battery was completely dead. I must not have had the cord plugged in to my lighter, or maybe it wasn't sitting properly on the cradle, and it was running on battery power. I found that when I charged it by the computer, it was ok. It is working with no problems, now.
Mar 10, 2008 | Garmin StreetPilot c340 GPS Receiver
Street Pilot C340
The only way to update the maps is to purchase new maps from Garmin and download them via the computer. The 2008 map updates are currently available, and Garmin has told me new maps will be out in a few months.
Mar 09, 2008 | Garmin StreetPilot c340 GPS Receiver
Display problem
Have you tried resetting the unit? It sounds like you may have a problem that Garmin needs to address. I would try to reset it first, then make sure you have the latest firmware loaded on the unit. If you still have the problem, it may have to be sent to Garmin for repair.
Feb 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps
It still should be under the one year warranty with Garmin. Call Garmin support and get a RMA.
Nov 25, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
52 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
