Question about GE Profile Spectra JGB920 Gas Kitchen Range
GE JGB920 Gas Range problem
I have a GE JGB920 gas range which has developed a problem that is not covered in the manual. The probe and bake indicators blink alternately and I am unable to use the oven. Pressing clear stops the blinking lights but after about 10 seconds they start blinking again. Unplugging and replugging the range doesn't solve the problem either. Does this mean the oven igniter has failed?
  • 3 more comments
  • ajk002 Mar 16, 2008
    Plugging in the probe did not fix the problem. I tried to take the probe socket out but the wire is too short to pull it out from the inside of the oven. What is the trick to getting the probe socket out?
  • Anonymous Mar 30, 2008
    I had this problem 18 mos. ago and had a service man come out but it would not repeat it. It solved itself until this week and now it starts blinking probe when it reaches 238 deg. but stops at 300 deg. No idea what to do. If I switch from bake to convention bake it works fine.
    rparks39@verizon.net.
  • gooberbob Mar 06, 2009
    I have a three year old GE Profile oven model #J25968SHSS . The probe and bake lights are blinking intermittently and the broil, proof and warm controls do not operate the stove. There does not appear to be any information regarding this issue in the manual.  The 5F code appears when the broil and bake buttons are depressed at the same time.. Can you assist me with repair ideas?
  • Gary Davd
    Gary Davd May 11, 2010
    no sounds like a probe socket short check that and let me know you can try to plug in the probe and see what happens
  • Dematrice Powell Jun 01, 2017
    What does it mean when all the lights are flashing on ge electric range glass top
  • 770 Answers
If not post your email i will send you the service manual
Posted on Mar 15, 2008
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
I have a GE JGB920 Gas Range problem. One igniter does not work. How do I change out the igniter?
Most gas ranges only have one ignitor (for the burners), so if one of the burners is not working, I would inspect the connection between the ignitor and the burner...not the igniter itself.
Jun 15, 2009 | GE Profile Spectra JGB920 Gas Kitchen...
Bake burner flutters
[ the glow coil } the ignitor is call needs replacing it'snot getting hot enugh to open the safety valve.it's no more then $45.00. Berry common problem.
Dec 09, 2008 | GE Profile Spectra JGB920 Gas Kitchen...
GE Gas Range
Do you have the manual? Normally , if I remember right it is either a sensor or control board. If it is a problem that can be solved w/o a tech the manual will give you sugesstions. I could be wrong on the code but you could try unplugging it for15-30 min then plugging it back in and try again. Don't have the manual? I'll try to find the code reference if I can.
Nov 03, 2008 | GE JGBP28 Gas Kitchen Range
GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Sep 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
F4 fault code
sounds like the meat probe is defective. have it replaced again.
Sep 13, 2008 | KitchenAid KGST307 Gas Kitchen Range
Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
May 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile XL44 range
I think it's the ignitor.   Ours has been doing a very slow lighting for quite a while.  I found if I did a cleaning cycle it seems to work a little better... otherwise a new ignitor  ( Ours is gas )...  now it is flashing the probe and bake lights alternately and will not turn the oven on at all....  not so impressed at this point.....
Sep 23, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGB920 Gas Kitchen Range Logo
604 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
