Key stick My imagistic fax/copiers 2500. The key stick and I cant progam any thing. I think one of the kid dropped something on the keys and numbers. Help
  • 82 Answers
Okay first thing you want to do is unplug machine, get some rubbing alcohol and an old tooth brush. then dip the brush into alcohol do not make it too wet and brush the edges of the keys as well as you can. If that doesn't work then you need to take the control panel appart and remove the board from the plastic panel and wipe with alcohol and rag/brush. BE SURE TO THOROUGHLY DRY BEFORE PLUGGING IN POWER CORD.
Posted on Mar 16, 2008
Fax Machine /phone L-80 The number keys stick or miss,why??
Feb 21, 2011 | Brother Office Equipment & Supplies
Imagistics SX 2100. When you change the drum what
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Jan 25, 2010 | Pitney Bowes Office Equipment & Supplies
How do you progam the 1 touch key? also delete a
Press the additional key button,scroll to no 3 faxsettings,press ok,scroll to no 5 pro touch key,press ok,Program the one touch keys from 1 to 12
Oct 06, 2009 | Canon ImageRUNNER 1670F Copier
Imagistics 2500 fax machine bought used - no book - how do I delete name/phone number of prior owner
press menu*2864 in quick succesion, should take you to test mode, enter 01 and then when that is done, enter 99 to exit test mode
Jul 30, 2009 | Brother MFC-8220 Fax
Faxing problem Imagistics 2500
You're correct, it's the scanner. Finding out what exactly is wrong with it is a little more difficult. First check the easy thing, scan a sample paper 4 times, each time pushing it against a different one of the four corners, and see if the line goes away or changes when you change the location of the paper on the scanner. If that doesn't work, take off the glass plate and clean it and everything under it, then try again. If none of that helps, download the latest drivers.
Please rate, thanks!
Mar 13, 2009 | SMC Accessories Chembook 2500: Port...
Imagistic 2500 Fax problem.
On top of the toner cartridge there may be a blue slider for cleaning the charge wire.
If not, you have a bad toner cartridge (drum cleaning blade)
Sep 16, 2008 | Brother MFC-8220 Fax
Need help to connect my dell laptop to imagistics 2500 printer please
it is possible to set this multi-function fax/copy/printer for printing from your laptop. There is an available GDI driver from the manufacturer's website ( for Windows Vista 64 (exe file). Other than that it should install like any other printer.
Jul 01, 2008 | Computers & Internet
Imagistic 3510/ sharp 350 scan
yes we have the product key for some units that serial numbers don't match.
we did not swap out the board in the scanner.
yes we know how to reset the hard counter.
what I'm being told by other boards I belong to is it's pretty hard to get around not buying another scanner kit. These machine come ready to scan if it has a nick card, but you have to spend another 400.00 if you want it to do it. I would be glad to pay a reasonable price for a trick around this.
Mar 18, 2008 | Office Equipment & Supplies
Brother MFC 9180 - Wrong operation signal
Press every button on operation panel, I've known this model to get em stuck , please define if input is noticed in display and if mode switch ie fax, copy operates if key isn't stuck.
Jan 30, 2008 | Office Equipment & Supplies
55 people viewed this question
