Help! My screen won't reconfigure to anything but 640 by 480 pixels and now it doesn't seem to be able to find the right driver. I may need glasses, but this is ridiculous!
  • pnlinsurance Mar 17, 2008
    IBMad: I have an Acer 1710 laptop only a few years old. Everything was fine then I turned it on and poof. I attempted to use the 'troubleshoot' and tried to reconfigure the monitor through the control panel~>display~>properties....etc... and the wizard. Cannot find the necessary driver list to update the driver.... no listing at all for available drivers..
  • Matthew Haynie
    Matthew Haynie May 11, 2010
    Is this a PC or a laptop? What is the brand of your computer? How old is it?
    Problem Solver:
If you have winxp flush your drivers uninstall everything that has to do with your video car and reboot A+ Larry
Posted on Mar 15, 2008
LG W2261 VP HDMI problem, 1920:1080 doesnt fit right, there is 2cm dark screen at the edge of the display Got drivers installed for analog -vga and digital -hdmi Tried the buttons on monitor...doesnt...
This problem seem to be the LCD screen have dead pixels or a bruise spots on the LCD screen itself that why you have dark spot or spots on the LCD Screen.This problems can't be repair because this problems doesn't causes by the electronic circuit boards.Tried move the monitor as an angles to the right or to the left might help some lessen the dark spot on the LCD screen that all you could do.If this problems is a very dard bruised spot will not help all or if it is dead pixels on the LCD screen itself.
Nov 21, 2012 | Computers & Internet
What is the part number for glass on 60pg60
Usually plasma TV problems start with the screen. If the plasma screen is broken or crashed, it's not repairable any more . It needs a new plasma screen replacement, which may cost you more then the plasma TV itself. ( new screen run ..2 -3k in real life .) Budget management !!! Protection front screen (glass on front) can be easily replaced and not so expensive as PDP panel behind it. If you have just protection screen damage your screen(PDP panel) will work without any problem . Plasma screen contains - aluminum base and two pieces of glass with gas between them ( gas inside not rechargeable ). Pixels with gas , controlled by small electrodes . Each pixel contains 3 colored sub pixels : they are green, blue and red. Plasma screen works in 2 steps:
--- gas ignition
Dec 17, 2011 | LG 60PG60 60 in. Plasma HDTV
I have a red dot on the screen. I tink its a dead pixel? Can this be repaired?
There are 2 ways you can try to fix dead pixel: Try online tool like
Try this quick guide to fix dead pixels
  1. Turn off your monitor.
  2. Get yourself a damp cloth, so that you won't scratch the screen.
  3. Apply pressure to the area where the stuck pixel is. Try not to put pressure anywhere else, as this may trigger the creation of more stuck pixels.
  4. While applying pressure, turn on your computer and screen.
  5. Remove pressure and the stuck pixel should be gone.
If none of these works, than you can't do anything with it.
Hope it helps
Jul 12, 2011 | HP w1907 LCD Monitor
Water spill on my AOC2216Vw LCD Monitor
Hey man, thanks for coming to me. Um yea, massaging may help but too hard will do damage since it is LCD is Liquid Crystal Display and it is fragile and easy to damage. The water should clear up in a few months, if not i would look at replacing it which can be costly. Here is a link to fix your unstuck pixels]
Now im not liking that bit about how you mentioned was spreading so leave it for about two days, give the therapy for the screen a try and let me know if the laptop screen is healing. For the moment if you have one i recommend you hook up a VGA Monitor, old school stuff if you can and give the LCD a rest. I will post as a solution but comment back and i will keep helping you as much as you need it.
Dec 21, 2008 | Computers & Internet
Screen resolution
HAVE you tried the key Fn along with the key that marked brightness sign togehter
Nov 11, 2008 | IBM Computers & Internet
Pixel damage
Those small pixels are now damaged not much u can do with it. Some people say you can press on the screen the pixels affected and possiblilty get them to make contact and light back up ( I honestly highly doubt it) If u can live with and not very distracting keep watching it. But if you want to order a replacement, more than likely it will cost more than the TV did when u bought it. If its still under warranty get it replaced if possible.
Jan 28, 2008 | Philips 42MF531D 42 in. LCD Television
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
