Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
Duet error code for door (by 5 users)
posted by harbrinn on Mar 15, 2008
duet error code for door lock
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by jlroddy, posted on Sep 29, 2008
We have had the same problem. A tech came out to look at it and wanted way to much to fix it, but after he left it worked fine for a few months. Now it is back to getting stuck on every load.
Comment by JIGomez10, posted on Sep 04, 2008
I also have a problem with the door lock on my KENMORE ELITE HE4T . I can here it clicking, but it won't lock and then I get the DL, F code with beeping. My washer won't start without the door lock engaging.
Comment by Guest, posted on Sep 02, 2008
I also have a problem with the door lock on my Duet. I can here it clicking, but it won't lock and then I get the DL, F code with beeping. My washer won't start without the door lock engaging.
Comment by ccardenas, posted on Jun 26, 2008
I am having problems with my neptune mah5500b
the door is not locking, the lock door light in the front panel is always off, machine won't start
Solution #1
posted on Mar 15, 2008
Not Rated (0)
Master_Tech
Rank:Guru Guru
Rating: 88%, 609 votes
DL=Door Lock Fault
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on duet error code for door:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Roper RAX4233PQ Top Load Washer
Roper RAX4233PQ Will start and fill with water but then...
Miele Touchtronic W1213 Front Load Washer
The main wash light was blinking. I called customer...
Frigidaire FWSB5700DS Top Load Washer
My washer won't spin any more.any help is appreciated. I...
Washing Machines
took rubber seal of beko washing machine cant get back on...
GE WBSR3140DW Top Load Washer
My GE top loading washer seems to have all the problems...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
