Panasonic SA-AK57 Every time I try to play a cd I get an error, it tells me "No disk." This happens no matter which tray I put the disk in. Any help would be appreciated.
  • Anonymous Dec 24, 2008
    Exact same thing. Doesn't matter what CD it is.
  • Anonymous Jan 11, 2009
    I have the exact same problem. The CD player will not work at all, I cleaned the disc and tried many other things, including unplugging the stereo, putting different CD's in etc. I even used a can of air to try and clean possible dust inside, but no change. My stereo is about 1 year old, just past the warranty and I don't even use it that much. What a disappointment.
  • 4,234 Answers
The optics assembly is not detecting the disk. Sometimes this is due to the lens being dirty. These units are not the easiest to work on with out either experience or the manual. I would suggest that you invest in a service call to have the optics checked.
Dan
Posted on Mar 18, 2008
RCA RS2664 Stereo wont play CD in any of the trays but seems to try to scan to play.
Hello
The laser pickup unit's lens may be dirty or dusty. Just put a lens cleaning disc into the tray, and play it at least three times, by ejecting the disc each time, and reinsert in in to. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. If it dose not help you, the laser pickup unit of your RCA device should be replaced with same type and number. OK.
Jan 25, 2012 | RCA RS2664 Shelf System
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't read.by the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Oct 25, 2010 | Microsoft Xbox 360 Console
Advent K4000 CD/DVD Drive Wont load the disc...says no disc present
What are you doing with it? Trying to record a CD? I don't know why, but that happens sometimes when trying to burn a CD, no matter what you do. Try being sure the tray is shut good, open & close it again, and if that isn't it, then try a different disk. A few days ago, I had an expensive disk that just didn't get found in mine, & nothing helped but a different disk. Then no problem. Hope it's not your last 1. :) If those things don't help, come back and ask more, & tell us what you tried, please. More info= better answer. :)
Sep 18, 2010 | Acer TravelMate 4000 Notebook
2001 Lexus LS430 6 Disk CD Player ''CD ERROR''
The sixth place is where the cd that was being played has to be put before it can take another cd to play. there should be a reset button some where im not sure where yet but I will find out and let you know shortly.
Aug 27, 2009 | Car Audio & Video
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Dec 05, 2008 | Audio Players & Recorders
Open tray error
Your problem is that your Xbox 360 cd drive, the ray inside it is scratched, get a cd drive cleaner and it will be fixed.
May 27, 2008 | Microsoft Xbox 360 Console
Xbox 360 open tray error
How I worked around the "Open Tray" problem, where the game discs were not being recognized:
1. Open tray
2. Unplug power cable while tray is open
3. Plug in power cable
4. Power on console - tray closes
5. Open tray
6. Insert disc
7. Try your game
Good luck! Source: Someone else mentioned this in a forum somewhere, however I don't recall who it was or which forum. I'm just trying to get the word out so people don't send in their XBOX for repair, or open the case and void the warranty if this workaround resolves the problem.
Mar 25, 2008 | Microsoft Xbox 360 Console
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
241 people viewed this question
 Grubhead
Grubhead
