Hi Tim and welcome to FixYa. I am Kelly.
I will be replying 2 times here but wanted to send this first one now so you can possibly check the lid switch. The machine will fill and pump out but if the lid switch is not functioning it will not agitate or spin.
As you just open or close the door or lid you should hear an audible click from the micro-switch. If you do not hear that click, The lid switch has a problem. (loose or failed)
The model number does not cross:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=970-C29052-00&=part+number&pathTaken=partSearch
Search results: "970-C29052-00"
We're sorry. No exact or partial matches were found.
This is a common lid switch:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Lid-switch-assembly-item-number-AP3100003.aspx
but may not be yours due to the model number issue.
There are 2 other possibilites also. One being the water level control or pressure switch and the timer assy. Most of the time the lid switch is the failure.
Thanks for using FixYa,
Kelly
