Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Removal of data
I would like to remove all the data on SanDisk 512mb cruzer micro usb and start with a clean slate
    Genius:
  • 3,587 Answers
Try a full format from my computer, select drive, and then choose full format..
if you want to back it up first, click here(2Gig freebie)
Posted on Mar 16, 2008
Sandisk 4gb cruzer micro showing 0 bytes and not accessible, i have valuable data in it
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you willlose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Feb 04, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 2gb cruzer micro usb broke
if the usb connector broke off of the board inside the plastic casing, no, you wont be able to retrieve the data.
May 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What do micro cruzer sandiscs do
your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the files or folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected files or folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My laptop does not see my sandisk when I plugged
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
Feb 03, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
How to remove write protection from Sandisk micro cruzer thumbdrive?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format thumbdrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 07, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro USB I/O device error
I would recommend plugging your Cruzer into another computer. It's possible that your computer has corrupted or incorrect drivers for the flash drive. This is one cause of the yellow alert in Device Manager. If you move the flash drive to another machine and it works, you can save your data and make a backup copy. If your Cruzer doesn't work in a different computer (I would try at least 2 other working computers), it's possible that the flash drive is faulty.
May 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cannot remove write protection on sandisk cruzer usb pen.
The memory cards also have a write protection switch to protect data from being deleted or overwritten, just like a floppy disk
Dec 03, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
HI GIPI
What the reciever you use?
If it's really compayible and support the usage of Flash Drives then the problem can be easily solved by removing U3 that comes pre-installed on these Flash Drives.
Let me know if you need any guidance in removing it.
Sep 16, 2008 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I needs driver for Sandisk cruzer 512MB SDCZ6-512 Please download Driver
http://www.sandisk.com/Retail/Default.aspx?CatID=1353
Sandisk how has a generic FlashCP (locking mechanism for files on their cards) ...it is SDCZ-xx where "xx" is any version.
Otherwise you souldn't need a special driver. Your operating system should recognize the thumb drive when it is inserted into the USB port and load the driver automatically. If it doesn't then there may be some problem with the USB port or the USB port driver.
Jun 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dropped my sandisk cruzer micro 512MB flash drive, computer cant read it now
I have had the same issue. Sometimes static builds up and discharges into the drive. Most USB drives are made to tolerate such problems, if it's fairly new and not obviously damaged outside, send it to sandisk for a replacement under the "poor workmanship" clause.
Nov 05, 2007 | SanDisk Cruzer Micro MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
