Convergence I have an rca 52 inch. I was told that the problem is the convergence. I have the ambition to fix things but where do I start. I need step by stop instruction. My TV is only a year and a half old. They want $120 to come out plus parts and labor?
    Scholar:
  • 146 Answers
What they told you is true. RCA's convergence output sections are very dependable, but the power supply for the convergence can give a problem from time to time (not very often). The way to conferm this problem is to take off the back cover at the bottom of the back, and mesure to see if the power supply is putting out voltage. If it is not (with the tv on of corse) then replace the power supply. If you are not a tech it will be very difficult to tell you how to do that, Sorry.
Posted on Mar 15, 2008
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 inch RCA model # R52WH73. The picture is blurry and double. What do I need to do to fix it?
Ur convergence is dead,need a convergence kit,know how to solder right?Tries these websites.Tv Repair World.com,Ebay.com.
Oct 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
All i can find is advanced picture settings under the menue
yes it should be under settings. If not its disappeared you can fix it yourself for 22.00 which includes the parts and detailed instructions with pictures that show how to do the repair. Heres a link to that kit.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-itc222-convergence-option-missing-repair-kit/cName/repair-kits
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence
if you cant converge from menu. your convergence ic is going bad.
Jun 02, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
52 inch rca look like 3d picture
You have a convergence problem. The Red and Blue are out of convergence meaning they are out of synch, causing shadows. There should be an Auto convergence option either on the television or through the menu options on the remote. If this doesn't fix your problem, then there's a manual convergence option. Should that fail, a service call is in order. Best of luck!
Greg
May 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
