My 2002 GMC Yukon horn does not work, Where do i start to look to fix the horn? I already checked the fuse box cannot locate the exact fuse for the horn? not in manual.
Any assistance is greatly appreciated?
Check the fuse box under the hood. i checked the one on the inside of door w/no luck also. i found a larger gray one there that was labeled horn
Yes - that was it.
The larger box under the hood did have the fuse for the horn? Where did you ge the fuse from and does it work now?
the fuse is number 15 and it was out. Replaced it now my horn and alarm works. Thanks a lot. GOD bless.
Sometimes there is a diagram on the fuse box cover that indicates which fuse is for what. But you definitely started in the right place. Maybe take the time to go thru every fuse see if any are blown. Hope this helps.
