Question about Dishwashers
Miele Dishwasher G856 SC cleaning assistance
For so long I felt as though our filter never needed cleaning.  Now, there is food in and around the filter bottom.  I will clean filter, should I run it with vinegar or anything special to really clean it out?  How do I clean out the bottom 2" of dirty water? Many thanks, sue
  • sueandbob Mar 16, 2008
    I am thinking Master Tech that you mean w/o soap and no dishes inside?  Any particular setting or just the most efficient which is what we currently use.  Could that maybe be the problem that we should occasionally use a longer cycle?
    Many thanks,
    sue
  • Anonymous Mar 15, 2014
    miele dishwasher. getting suds. sometimes at last rinse. when doing just rinse don't get suds once I clean and flush suds with vinegar several times.
  • 770 Answers
Yes run a cycle with 2 cups of vinegar to flush it out
Posted on Mar 15, 2008
The Dishwasher stop working and the red lights come on telling me to add Salt. Where do I add salt and what kind of salt?
Posted on Oct 11, 2010
Water will not drain out of bottom of machine.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Miele G880 Dishwasher
My Miele dishwasher is about 16 months old. Initially it was awesome. Now it doesn't get anything truly clean on any rack. Every item has scum and traces of food or drink left on it. I've cleaned the...
Hi bjw.... clean the dishwasher by putting 2 cups of vinegar into an empty dishwasher and running the longest and hottest cycle.
Repeat this washing as needed but generally at least once a month. Joe
Thanks for choosing Fixya!
Feb 27, 2011 | Miele G880 Dishwasher
My Miele Platnum dishwasher is not working. It is flashing "intake/drain" When it begins instead of the normal hearing of water moving around you just hear a humming. My husband and father took out all the...
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 03, 2010 | Miele 23 in. Novotronic G841 Built-In...
My miele G665 SC is not draining all the waste water away at the end of the cycle, i've taken the filter part out of the bottom and it's all clear and even run a cycle without it, is there another filter...
Hope this helps.
Jul 02, 2010 | Miele 24 in. G665 Built-in Dishwasher
Miele g 892 sc intake/drain light is lite and unit will not operate
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Apr 25, 2010 | Miele G892SC SS Dishwasher
Trying to find the dimensions of the Miele G694 SC Toughtronic Turbothermic Dishwasher. It doesn't appear to be the standard 24 inch size and wanted to verify the dimensions before I replace it with...
if you go to the Miele website you should be able to download the manual for the machine if you don't have one and in the installation part of the manual this should give you dimensions. if not Miele service dept should be able to help.can't give you tel number as i am not sure where you live. the website will direct you though.
Dec 03, 2009 | Miele 24 in. Touchtronic G694SC Built-In...
Miele Dishwasher is not cleaning dishes
check the filters. also check drain. Sounds like it's not fully draining and/or there is not enough water (ie. when filter are clogged)curculating to wash the dishes properly
Jun 08, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwashers Logo
1,822 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
