Question about Kenwood KDC-MP235 CD Player
Wiring for a 99 jeep cherokee
I need to know the wiring configuration. i have 14 wires out of the stereo and the harness i purchased has 16 wires. also which wire is power for the factory amp. HELP!
thanks
    Problem Solver:
  • 4 Answers
On your vehicle there should be two male plugs from the back of the radio, one black and one gray. The simplest thing to do is get an after market harness but if you really need the wiring,here you go:
12V+ Pink/Yellow
Acc Red/White
Ground Black
Illumination (not really needed) Orange/Brown
Dimmer (also not needed) Black/Light Blue
Speakers:
FL + Dark Green
FL - Brown/Red
FR + Violet
FR - Dark Blue/Red
RL + Brown/Yellow
RL - Brown/Light Blue
RR + Darl Blue/White
RR - Dark Blue/Orange
Posted on Apr 10, 2008
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • Dec 24, 2010 | 2006 Jeep Grand Cherokee
    How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
    Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
    Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
    Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
    1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
    CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
    1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
    • Cruise Control Information • Stereo Information • View all Jeep Vehicles
    Dec 18, 2010 | 1996 Jeep Grand Cherokee
    I bought a cd player for my 94 grand cherokee and bought a wiring harness for the speakers. And. I want to kno which colors are the speaker wires
    1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Pink
    Car Radio Accessory Switched 12v+ Wire: Violet/White
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Orange/Black
    Car Stereo Dimmer Wire: Green/Red
    Car Stereo Antenna Trigger: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Green
    Left Front Speaker Negative Wire (-): Brown/Red
    Right Front Speaker Positive Wire (+): Violet
    Right Front Speaker Negative Wire (-): Blue/Red
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown/Yellow
    Left Rear Speaker Negative Wire (-): Brown/Blue
    Right Rear Speaker Positive Wire (+): Blue/White
    Right Rear Speaker Negative Wire (-): Blue/Orange
    google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
    Dec 11, 2010 | Cherokee Jeep Grand 1994-1995 Radio...
    Well i have a 1994 Jeep Cherokee. I switched out this stereo which is a Pioneer DEH-1800. It is installed in the jeep. It recieves power and everything. But nothing is coming out of the speakers. But i am...
    First you will need to know if this vehicle has a factory amp. If so you need to find the wire to power it up. If no factory amp you need to test the audio output of the stereo itself.
    Aug 22, 2010 | Cherokee Jeep Grand 1994-1995 Radio...
    How do I install my Pioneer MOSFET 50wx4 Super TunerIII in my '93 Jeep Cherokee?
    When you go out and buy a new stereo make sure to buy a wire harness kit and a mounting kit. The back of these packages will tell you if it will work for your vehicle. As long as your son properly removed the old stereo, all you should have to do is plug one end of the wire harness into your stereo, the other end into your car, and you're done, no wiring needed. If he cut the wires you may be better off going to an auto shop of some sort to have it installed.
    Jul 04, 2008 | Car Audio & Video
    99 jeep grand cherokee turns off while iam driving
    Jack up your Cherokee and look underneath for a wiring harness that leads to a sensor that is between the engine and trans. This is your crank sensor. Pull it out and check the condition. Mainly look at the wiring harness to the sensor. These Jeeps have a habit of breaking and your Jeep with just turn off going down the road. These wiring harnesses are available at the dealer and are fairly inexpensive.
    Jun 21, 2008 | 1999 Jeep Cherokee
    Kenwood KDC-MP235 CD Player Logo
    107 people viewed this question
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
