SOURCE: 2005 Canyon turn signal problem
No, but that's probably where your problem is. The wires get the hell beat out of them by stones, and then they short out and cause problems. I would take a look at it.
SOURCE: Brake light, reverse light and turn signal issues
Hello. The symptoms you are describing are likely due to a poor ground. Temporarily install a new ground wire by securing a piece of copper wire to the frame with a self tapping screw. Use this ground wire along with the hot wire to see if each of these lights works. If it does, trace the ground wire back to the frame, unscrew it and clean up the metal with emery cloth so you reestablish a good ground.
