Question about Toshiba Satellite A45-S150 Notebook
Display problems When I start my Toshiba Satellite up, the display looks fine - but then after several minutes the colors turn all strange and you can hardly see the screen. Any ideas on what is causing this? Would it be something I could fix myself?
  • Momk6 Mar 15, 2008
    In 2005 when it was under warranty, it was overheating and was fixed. This display problem started a few months ago. The fan is running, but it seems like it does not shut off. The computer is approximately 5 years old. Thanks
  • 85 Answers
Can you hear any fans spinning at full speed? Are they spinning at all? Either way, sounds to me like your CPU or GPU is overheating, causing display artifacts. I'd take it down to a computer repair shop if the fans aren't spinning very fast or aren't spinning at all, if they are spinning, try to blow out any dust that may have accumulated over the years. By the way, how old is this laptop? I don't think it's the display itself, if it were, then it would be having problems right from the bootup. Also, if you take it down to a computer repair shop, ask them to check if the thermal diode is working.
Posted on Mar 15, 2008
SOURCE:
My toshiba display has turned really dark. the icons are all very dark and you can barely see the start button. the icons have mixed colors like the rainbow in them!! i did a complete system restore but...
You do not say how old the machine is or how much use it has had. Sorry to say, it looks as if the tubes that support the display are failing. In short, the screen needs looking at by a computer repair shop.It may be able to be fixed.
Aug 12, 2010 | Toshiba Satellite P30 P35 Series Notebook
Toshiba satellite a305-s6905 video problem
you probably have a loss connection between the motherboard and screen or try to update your video driver.
Apr 11, 2010 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
My satellite toshiba laptop shows a screen of fine colorful lines
did you ever try to go on gateway site to find a fix or microsoft.com to see if there is a update display driver for you computer
Feb 10, 2010 | Toshiba Computers & Internet
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellite display problem
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Thankyou
Nov 26, 2008 | Toshiba Satellite A60 Notebook
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
Replace monitor?
how to take the monitor off the laptop and replace
Aug 19, 2008 | Toshiba Satellite A105 Notebook
A105-s2716
The problem with the LCD screen , if the external display is working fine. The LCD needs a replacement. The same thing happened on my Dell and we had to replace the Lcd. The same can occur because the LCD cable gets damaged when you open or close the LCD
Thanks
Proton
Aug 02, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A45-S150 Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
