Question about Zenith ZHD-311 300W Complete Home Theater Sound System, Progressive Scan System
Dvd I have a problem with my system it seems i press the setup button and when it prompted me if i wanted progressive scan my screen stop showing the dvd i was watching and my lcd television is showing a blank screen and it says "no Signal" please reply if you could help with this situation.. Thankyou Jamal
  • Anonymous Jul 30, 2008
    I was in Set up and it asked me if i wanted progressive scan and i said yes. Then the screen goes blank and dvds dont play and the logo in the beginning dosent show. Please help
Hold the play button for a lil bit it will come back
Posted on Apr 02, 2008
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Turned progressive scan on, can i turn it off without being able
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode." The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter. Hope this helps you with your problem
Apr 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Need to turn OFF progressive scan on Sony DVD DVP-NS57P
With the remote: While in STOP mode, press the DISPLAY button. Use up/down buttons to select SETUP. Press Enter. Use up/down buttons to select CUSTOM.Press Enter. Use up/down buttons to select SCREEN SETUP. Press Enter. Use up/down buttons to select PROGRESSIVE. Press Enter. The manual is a bit indistinct after this, but I think the prompts will direct you. Just turn Progressive OFF.
Owner's Manual page 61, link http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/DVPNS57P.pdf
Nov 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Progressive Scan Mode
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
Jan 29, 2008 | Zenith XBS344 System
Progressive scan
I have a zenith dvd/vcr receiver model LH-C245M i accidentally put it on progressive scan mode and appears on on my TV screen how can i get back to normal viewing? can you help me with this one Please. Thank you hoping for your great response.
Jan 11, 2008 | Progressive DVHE210 210 DVD Player
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Progressive Scan
SOLUTION #1
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
90 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
