Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
52inch RCA model#D52W20 tv
Will not turn on. The light blinks once and then 9 times. I can hear it try to turn on but doesn't.
  • 3 more comments
  • Anonymous Jun 04, 2008
    The green light comes on but no picture or sound - It then goes off.
  • Gustavshack Jan 31, 2009
    hit on botton and hear noice no picture. Took apart looked at the bulbs below and one bulb trys to turn on other two do nothing?
  • Anonymous Mar 09, 2009
    Wow, Is this a defect or something? I have a RCA 52in D52W20. Will not turn on. When the power button is pushed on the little green light in it will come on for 5 secs., off 3 secs., on 5 secs., off 3 secs., then on one more time for 5 secs. BUT if the button is pushed and held it will flash once, a pause, followed by 9 more flashes. Is that a diagnostic code like you can get from a car? The previous owner could do something to it to get it to work, then would leave it on and use a cable box. No clue what he did.
  • xiaodong8357 Mar 13, 2009
    I have the same problem.
  • Anonymous Mar 30, 2014
    hook computer to tv
    Genius:
  • 1,030 Answers
The d52w20 rca chasis itc222 can be difficult to troubleshoot sometimes. there a few things you can assume at this stage. ONe it is NOT the fuse. The processor in this set is seeing a voltage or saftey shutdown issue. and is shuting the set down for saftey. THis is where the troubleshooting begins. High voltage or overcurrent conditions are generely the problem. \technicians have speceil computer diagnostic equipment that can read error codes in the processor. much like in a car. but without it yo0u pretty much have to check things like horizontal ouput transitor.
Posted on Mar 16, 2008
SOURCE:
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
52inch rca rear projection power button turns green but tv will not turn on will replacing the capacitors repair this problem
Often it will, But the Flyback transformer is also famous for failing in that Model which can cause the same symptom. Caps should alwasy be tried first with that model.
Oct 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I OWN AN RCA 52INCH REAR PROJECTION SCREEN TV...WHEN I TURN IT ON...A GREEN LIGHT APPERARS AND BLINKS 3 TIMES AND STOP...WITH NO PICTURE OR NO SOUND....PLZ TELL ME WHATS THE PROBLEM?...IS IT WORTH...
24.95 the kit is called the CP150, CP114 and CP120 capacitors repair kit listedunder RCA reapair kits at www.tvrepairworld.com The kit contains the capacitors and detailed instructions on CD
Nov 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52inch TV
there are some capacitors on your deflection board go bad they are going to be swollen and right next to behind a haetsink is anothe rone
Nov 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
571 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
