Question about Brother SE-270D Computerized Sewing Machine
Changing needle/thread When using the walking foot and I need to change the thread, unless I take the walking foot off, the needle hits the foot and breaks. It only does this with the walking foot. Is this normal? thanks
    Problem Solver:
  • 14 Answers
Yes, you have to remove the walking foot, the threading mechanism does not have electronic recognition of different feet so when you add a foot that has a different fitting you will have to remove it to self thread.
Gale
Posted on Mar 23, 2008
SOURCE:
What settings should my elna 410 be on for thick fabric such as canvas
You may want to change the tension slightly to make sure the top & bobbin threads meet in the middle of the fabric. Use a heavier needle and thread. Increase the stitch length. And possibly change the presser foot pressure or use a walking foot, roller foot, or teflon foot. If the pressure is too heavy, the presser foot may "push: the top layer of fabric in front of it so the top fabric is slightly stretched or puckered.
Jan 04, 2018 | Elna Sewing Machines
I am using the walking foot for a quilting project that I am working on, however, the bottom stitching is just looping and can just be pulled away from the fabric.
Be sure you are using a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE THE PRESSER FOOT and rethread the upper thread from the beginning. Make sure the thread path is correct.
Verify the bobbin is installed and turning the correct direction in the bobbin case and that the bobbin thread is threaded through the bobbin tension mechanism.
Set the upper tension to the midway point between high & low number--this may require some adjustment for your particular machine.
Pull the bobbin thread to the top of your sewing project before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Re-test your machine on a scrap quilt sandwich (make sure the walking foot is installed correctly and that the presser foot is lowered when beginning to stitch).
Consult the owner's manual for instructions for presser foot pressure. The pressure may need to be adjusted because you are dealing with a sandwich that is thicker than regular fabric.
You may also try changing the type and size sewing machine needle you are using. Using a Top Stitch or Microtext needle will help the needle to penetrate the fabric sandwich easier. A Top Stitch needle has a larger groove to protect the thread as it pierces the fabric which helps prevent looping.
Also, verify the thread is not too small for the needle's eye.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwil1tu2mb3PAhVR6mMKHUlvB_4QFggoMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Oct 02, 2016 | Sewing Machines
Replaced broken needle clamp, but presser foot blocks needle shaft from going all the way up & the drive wheel cannot complete a turn to pull thread.
I'd need to know what type of machine you have, but maybe you aren't putting the clamp on correctly. They are fussy! Be sure you have the flat side of the needle facing the correct way and that you wiggle and jiggle it while pushing up on the needle. Also, make sure you are using a new needle and not the old bent one. Sometimes the clamp will come in 2 pieces, so it may not have broken, just came undone.
Dec 30, 2015 | Sewing Machines
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
How do attach the walking foot Brother
Jun 26, 2017 | Sewing Machines
Walking Foot Trouble
sounds to me like you are getting what I call "flagging" of the material... where a tiny bur or something catches the material and pulls it up. If possible increase the presser a bit on the presser foot. You might also have the wrong foot for the machine or simply a defective one.
Also when it does this... do you notice any bobbin thread on top of the seam?
Feb 25, 2013 | Baby Lock Sewing Machines
Error E6 and E!
the needle needs to be changed since it's hitting the walking foot
also the machine could be out of time since the needle is hitting the walking foot
it needs to be serviced
Jan 24, 2012 | Brother CE4000 Computerized Sewing Machine
My needle on my Esante seems to be hitting something the skipping stitches. I have changed needles, rethreaded, changed plates, and changed feet. Thanks
Did you thread the machine with the presser foot up? Is the needle inserted with the flat side to the back of the machine?
If so, and the problem has not changed, check the bobbin case to be sure it is correctly placed into the race. Leave the needle plate off as you hand walk the needle down. If it hits the case, it is not in place.
All the above has been done and problem continues, take the machine in for service as the timing may need adjusting and is a process best done my an authorized Brother dealer.
Mar 11, 2010 | Baby Lock Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
I have been using my pe150 without problems than sat down today and started a pattern and it will not sew I keep getting upper or lower thread broken, they are okay I have changed the needle also. I don't...
sounds like you may have a burr, probably on the bobbin case will be very small can be sanded off, caused when the needle hits the bobbin case could also be on the walking foot
Aug 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
196 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
