Question about Mitsubishi WD62527 62 in. LCD HDTV
TV won't turn on.
When I power it up, both the lamp light and the status light blink slowly. The lamp flashes green and the status flashes yellow. After about one minutes, only the status light flashes. According the the manual, a yellow status light blinking indicates an open fliter door. I've secured that several times. No where in the manual does it say anything about a slow blinking green lamp indicator, much less both the lamp and status indicators blinking at the same time (green and yellow). What can I do?
  • Robert Johnson May 11, 2010
    when was the last time you replaced the lamp? how long have you owned it?
  • bjmitch99
    bjmitch99 Feb 15, 2014
    I've owned it for about 1 ot 2 years and never have replaced the lamp. Don't know how to do that.
Lamp is bad need new lamp
Posted on Apr 27, 2008
SOURCE:
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
second.
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Mitsubishi WD-73638
lamp is gone needs replacement
Jul 08, 2013 | Televison & Video
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Jul 17, 2012 | Televison & Video
Status Light Problem
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
I hope this helps.
Jul 19, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
Mitsubishi WD62527 62 in. LCD HDTV Logo
1,686 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
