Question about Dryers
Whirlpool ultimate care gas dryer
Dryer is running, but isn't getting any heat. Propane is full and cleaned vent has been cleaned..... don't know what I should check next?
  • hirschmans Dec 18, 2008
    I have the same problem. Plenty of air blowing but no heat. it just stopped.
    Whirlpool ultimate care II
    President:
  • 1,314 Answers
The glow bar on the gas ignighter
Posted on Mar 15, 2008
SOURCE:
WHY IS MY WHIRLPOOL ULTIMATE CARE PLUS LEC8858EQO NOT HEATING UP
Perhaps you need to clean out the air vent in the back. it is most likely a tube and it is most likely full of dyer vent. when this gets cleaned out, it should help the performance of your dryer.
May 05, 2014 | Washing Machines
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My whirlpool ultracare !! dryer will not heat. I have to dry things over and oer and over til they finally dry.
i looked up your model number and that's to a washer not a dryer.if it's a gas dryer it sounds like you have bad gas coils located on top of the gas valve.the coils work until they heat up like in the first 15 to 30 minutes and they shut down,when they cool they work again until they heat up and fail,this is why you have to keep running thedryer,one more problem could be the dryer needs to be cleaned out.clean out the vent line,clean out the duct that the lint filter slides into and vac out the cabinet where the motor is
Jan 22, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My gas dryer has no heat
long dry times are a venting problem. if no heat at all it could be your ignitor, a thermal fuse, or the secondary gas coils, all are replaceable and reasanoblyy cheap between 30-90 dollars usually so its up to u it u want to repair it.. if long dry times i would unplug the venting from the rear and dry a load if it heats faster than u know ur venting is clogged and u might wanna clean ur ducting and replace that venting tube. also u can go outside while running and see or feel if air is being pushed out while its running hope this helps let me know how it goes
Feb 22, 2010 | Whirlpool LGB6300 Gas Dryer
The dryer runs and tumbles. It just doesn't heat up?
if it runs and you have no heat it is the ignitor, a cheap fix. It should cost less than $100.
If you have any heat at all it is the venting, clean out the vent from the dryer to the outside of the home and it will run just fine.
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
157 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
