Question about DeLonghi EC155 Espresso Machine
Problems with handle alignment
The handle on the filter basket holder on my Delonghi EC155 espresso machine aligns correctly when it is empty, but when I put the filter basket in it (even without coffee in it), I cannot get it to turn more than 45 degrees. I saw other people with this problem with handle alignment on amazon, and no one who has been able to fix it. I can't just leave it the way it is because the water leaks off the top/sides. Any suggestions would be greatly appreciated. Thanks.
  • R. Tan Nov 24, 2012
    I have the same problem Fresh00. Were you able to fix it and how?
    New Friend:
I had to use some olive oil around the outside of the filter cup holder to get it to move all the way to the right. After the first couple of times I was able to get it on straight without any oil...
Posted on Jan 05, 2013
  • 3 Answers
I DON'T THINK YOU ARE GETTING A GOOD SEAL ON THE PORTAFILTER . YOU HAVE TO MAKE SURE THERE IS NO COFFEE AROUND THE EDGES AND EVRYTIME YOU ARE DONE BREWING RUN SOME WATER INTO A CUP WITHOUT THE PORTAFILTER IN PLACE .
Posted on Mar 17, 2009
There appears to be a screw up inside where the filter holder goes that won't allow the filter holder to be turned! Is it defective or am I doing something wrong??
U.S. Residents:
Please contact toll free hotline at 1-800-322-3848 or log onto website at www.delonghi.com.
For all accessories, spare parts or replacement parts, please contact parts division at 1-800-865-6330.
Residents of Canada:
Please contact toll free hotline at 1-888-335-6644 or log onto website at www.delonghi.com.
Jul 08, 2014 | DeLonghi EC155 Espresso Machine
Tip
DeLonghi EC155 Doesn't Release Water
When I bought my EC155, I heated it up for 30 minutes and tried multiple times to run water through. After multiple attempts the water level remained unchanged. <br /> I was able to fix the problem by opening the bottom of the machine (4 star screws). After opening the bottom, I immediately noticed that one of the plastic pipes was not in the channel in which it was supposed to be and as a result was kinked and sealed off. I simply pushed it into the channel and that fixed the problem.
on Sep 14, 2011 | DeLonghi EC155 Espresso Machine
Ec155 delonghi
if you have an ohmmeter, disconnect the cables that feed the resistance and connects the ends of the meter should give a value of element 5 to 30 ohm, if you give infinite that is very high due replacement it, there are also two thermostats one limit and a control, if you use this meter their connections resistance removing the cables connecting them, the measurement should be 0, if it gives you another value or infinite must change.
Feb 09, 2014 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
I NEED A MANUAL SO I KNOW HOW TO USE MY dElongi Espresso EC155
You can download the user manual directly from Delonghi from this link
Sep 28, 2009 | DeLonghi EC155 Espresso Machine
DeLonghi EC155 Expresso Maker
THE PROBLEM IS THAT YOU HAVE TO STOP THE MACHINE ONCE YOU HAVE ENOUGH IN YOUR CUP . IS NOT A COMERCIAL MACHINE THAT WOULD GIVE THE RIGHT AMOUNT AND THEN STOP ....
Feb 18, 2009 | DeLonghi EC155 Espresso Machine
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
Espresso
the filter has a little indent that must be placed correctly, if you put the filter in the holder and then rotate the filter you will feel it click into place when it is in the right position ( there is a gap for the indent at the front of the holder)
Oct 30, 2007 | DeLonghi BAR 140 Espresso Machine
DeLonghi EC155 Espresso Machine Logo
1,172 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
