Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Tip of dvd imput cable broke off recessed in tv
Help! the cable was stepped on & the green input tip is recessed in the green hole/ input.
  • 121 Answers
The center of the tip should have some open space to carefully screw in a small screw (by hand) and pull out.
Posted on Apr 22, 2008
SOURCE:
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
How many wires go from DVD to TV and what colors are they?
Ok. If you have a tv that has a five hole input (green, blue, red, white, red) this is the preferred hook up. That cable is called a component cable. The green blue and red part is for video and the white is audio left and the red is audio right.
If your tv does not have the five hole input it should have a three hole input. Those colors are yellow, white, and red. This is called a composite cable.
You just match up the colors that's all. Your tv should have an input or tv video button on the remote control that would allow you to switch inputs or you may be able to get to video 1 and video 2 and etc by using the channel up and down button and going lower than channel 2.
May 06, 2010 | Sony DVP-NS575P DVD Player
Connect dvd recorder to cable box and hdtv
I have posted a tip that should help you out with your problem follow the link below but there is one minor variation for connecting to your TV.
On step 3 of the connections section substitute the follow for your situation.
You will need 1 component cable (Red/Blue/Green/Red/White cable)
3) Connect the Green/Blue/Red connectors to the back of the DVR labeled "COMPONENT OUT" matching the colors. Connect the same ends to the input of the back of the TV again matching the colors.
4) Connect the last two connectors (Red/White) to the back of the DVR to the AUDIO IN on the TV.
Other than this variation all shoud be the same.
CLICK HERE for complete tip.
Good Luck...
Jan 27, 2010 | Panasonic DMR-E55 DVD Recorder
Not sure if what I think are hex screws are actually that
Assuming that the bit head is flush with or recessed into the hex slot, I think it depends on how big the hex slot is, but if it's a clean break, you could use a strong glue (like krazy clue) or a cement (like PC7) and glue something to the bit (or the screw itself if you have a replacement) and then 'wiggle' the bit out. Often you can unstick the broken tip by applying pressure in the opposite direction that was applied when it broke just to free it up. You could drill into the bit just enough to secure a stronghold for gluing, say, the end of a coat-hanger into the hole.
Jul 21, 2009 | 1997 Saturn SL
Yellow input/output cable broken off in TV
you can use a screw small enough to fit in the middle of the tip of the cord.the tip is hollow so just remove any plastic or hard rubber that is clinging on the said tip.(use a big needle for this.)be careful when doing this.make sure that the unit is turned off and unplugged.after inserting the small screw,slowly twist and try to pull it gently until the screw is tight enough but not breaking, to pull the tip.
May 12, 2009 | JVC Televison & Video
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Coaxial Imput Jack Is Broke
Use your external jacks yellow red/white on video1 this will work other wise replace SSB board it cost 292.00
Sep 07, 2008 | RCA D52W19 52" Rear Projection Television
Imput channel or imput switch
if you scan down below channel 2 doesn't video show up? otherwise there should be a input / video button
Dec 31, 2006 | Zenith B27B40Z 27" TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
