Question about Mitsubishi XL8U Multimedia Projector
Mitsubishi xl8u projector
I recently bought this projector and the bulb was just replaced but now my display image is upside down when projected on the screen. How can I fix this?
Thanks Rick
  • 682 Answers
Go to menu and press it---press right or left arrow button and go to installation press enter.
--go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
Posted on Mar 17, 2008
My image is upside down after I mounted my projector to the ceiling
There are projection mode settings which will allow you to adjust the orientation of the image. Adjusting this setting will rotate the image so that it is not displayed upside down when attaching the projector to the ceiling.
To activate this setting:
  1. Press the Menu button on the projector.
  2. Using the Arrow buttons, select the Image icon on the left side.
  3. On the Image screen under the Projection label, select the icon that represents ceiling mounted projection. Note: You may see both front and rear ceiling mounted projection modes. You may choose which ever best suits your needs.
  4. Press Menu on the projector controls to exit the settings menu.
Nov 19, 2011 | Office Equipment & Supplies
Image is upside down on the screen
Alot of projectors (being all projectors that are designed to be hung from a roof) have an image flip function. This is because when you install a projector in a roof you have to flip the projector upside down so the projector doesn't have to be pointed down and doesn't cause any problems with keystoning.
If you have just bought a new projector and installed it in the roof or perhaps bought it second hand and are projecting from the floor (when the previous owner may have had it in the roof), you will need to go through the menu screen until you find this setting. I don't know exactly what Epson call this function but it should be in there somewhere. If you have it on the floor you want image flip off, if you have it in the roof you want vertical image flip on, horizontal image flip is for when your projecting onto a special screen surface from behind the screen.
Mar 24, 2011 | Epson PowerLite 3LCD Projector
My project image is flipped horizontally on the screen, but displays normally on my laptop. How do I fix my projector image?
The projector may have a menu function for flipping the image dependent on whether it is merely set on a desk, or mounted upside down on the ceiling. See the manual, printed or online.
Feb 02, 2011 | ViewSonic PJD6211 Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
Menu
Hi paulveldt
Very easy ! Simply go into the menu and look for the subfolder that will either read Mirror or Flip Image. Scroll down to it and press left or right until the image is back to normal.
A mountable Projector can project flat fronted ( on a table ) upside down ( on the ceiling ) rear ( from behind - on a rear projection screen ) and upside down from behind ( from the ceiling onto a rear projection screen )
This should do the trick !
Thanks for using Fixya !
Apr 30, 2008 | NEC VT676 Multimedia Projector
Problem with a Gateway 210 DLP projector
The color wheel may not be turning. Remove the lamp and see if it will turn manually.
Aug 08, 2007 | Gateway Projector 210 Multimedia Projector
Upside down projection
Download the latest display driver for your video card. If you are using ATI vc's then download and install the Catalyst Application which will allow you to rotate the screen orientation .
Jun 20, 2007 | Optoma H56 Multimedia Projector
Mitsubishi XL8U Multimedia Projector Logo
668 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
