Question about ASUS P5VD2-MX SE Motherboard
8400GS graphics card installed causing sound distortion
8400GS graphics card causes gross distortion to Start-Up sound and other sounds when in Windows Basic mode.
Other sounds OK in Windows Aero mode, but Start-Up sound still bad.
Remove 8400GS and everything reverts back to normal, but can't get Aero because onboard graphics is only 64meg.
I'm running Vista Home Premium, have 1024 meg Ram, 3.2 gig dual core, 180 gig hard drive, don't think it's the sound card, have tried several different types, all work.
Motherboard of course is: ASUS P5VD2-MX SE Is there a solution please.
    President:
  • 2,351 Answers
You do know you can increase your integrated video's memory in the bios. Up to 1GB. (Yes, I know you currently only have 1GB of system memory) but you can kick it up to 128Mb & Vista should still run.
Your 1GB system memory is shared with the on-board video card.
I'd like you to clean out the PCI-E slot with some cotton swabs & house hold Alcohol. (do not over soak the swabs). Clean the pny's copper contacts as well. Get a really strong flash light & look into the PCI-E slot & look for dust, dirt & check the copper connectors are not bent or twisted. Re-install the PCI-E card & set the bios back to PCI-E. Try again. Even if the system reverts to weird, install the 8400's software & driver. Re-start the system. See if the system runs normal. Also would not hurt to check for Window's updates. After all that, if system does not function normally I suspect there is something wrong with the 8400 card.
Good luck & let me know if this has helped.
Have a great day.
Posted on Mar 15, 2008
Want to install pny technologies gforce 8400gs ddr2 512mb pci graphics card but do not know how to deactivate my graphics card on my motherboard as I do not have a emachines 5250 manual can you help
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers to hope this helps http://download.cnet.com/%7Bvalue=http://www.download.com/asus-agp-v7100-deluxe/3000-2108_4-68331.html
ASUS AGP-V7100 Deluxe Combo v44.03:The ASUS AGP-V7100 Series graphics cards were created to provide mainstream PC users with the radical 3D/2D graphics and video performance of the GeForce2 MX, the 2nd generation GPU from NVIDIA. With the AGP-7100 Series and its support for the TwinView architecture, ASUS has made available the most variety of models to support several dual display output combinations using RGB monitor, TV, or digital flat panel
hope this helps
May 28, 2011 | PNY Technologies VCG84512SPEB GeForce...
About geforce 8400gs gen2 tc1g 64bit ddr2, it is okey to run in window7 32bit. i already install and run but only read 512mb.
There should be no reason why this card won't work with Windows 7 32bit, it could be as simple as your Graphics drivers are out of date. I recommend downloading the latest Windows 7 drivers for your card at the Nvidia website.
Just remember graphics RAM and SDRAM are two completely different things so they don't add up.
As far as I know the 8400GS is a 256MB card.
Jan 07, 2011 | HP GeForce 8400GS Graphics Card - nVIDIA...
Video card driver problems
If possible try to install mother board CD drives to rectify this problem or search for motherboard related video drives from net to download and install
Jul 16, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
I need help with a nividia 8400 gs
see that ur vga cable is inserted on a graphic card
and reset ur cmos
Jun 07, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
We have install the nvidiageforce8400 driver during installation showing scatterd display on the lcd what i can do for that
That can not be the right driver for your video card. I suggest you roll back to its previous driver. Look for the latest version of the driver for your video card.
May 20, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
Cant seem to install new graphics card
First uninstall graphic driver from computer.
For that when you power up the computer press F8 key then enter in safe mode.
Then go to device manager.
For get device manager right click on my computer iocn then click on property then hardware->device manager.
Then you can see all driver list uninstall display adapter graphic driver.
Also go to start->control panel->add remove program then select nvidia graphic driver and uninstall it.
Then restart computer.
then download exact driver for your model from below link.Then install in computer.
click here
Click on above link and select your model then download driver for your operating system then install.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 09, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
Computer graphics ,lots of colors then computer crashes i have a asus 8400gs card
Drivers most likely, remove the card and use the onboard or some other card that works. Then boot into windows and install the drivers for the new card, then power off, install the card in question and reboot and then try.
Dec 04, 2008 | ASUS P5VD2-MX SE Motherboard
Graphics card.
For your sound card how many plug in openings are you using on your card?If only 1 is all, than that is why.Try re-downloading your soft ware.If your running Vista, than your problem is that,Vista,just like XP started out ,many many incompatible issues with the operating system that will fix them selves with more time.Secondly your graphics problem:Are you using Vista????
You now have a start ,not stating what operating system your running is one problem.
May 12, 2008 | Computers & Internet
ASUS P5VD2-MX SE Motherboard Logo
296 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
