Question about Apex Digital GB51HD09 51" Rear Projection Television
Convergence After a thunderstorm, our GB51HD09 had a convergence problem. We found the convergence menu but could not get the crosshairs to move using the remote controls (one for DirecTV and one "universal" remote), although the remotes worked for other functions, like volume and channel. I'm wondering if the thunderstorm destroyed a tube or will getting a better remote enable us to fix the convergence. I saw a "substitute" remote for GB51HD09 for $57.00 on a Web site.
  • 1 more comment
  • ralphwayne Mar 15, 2008
    What is the "convergence amplifer output ic's"?
  • Anonymous Jun 02, 2008
    How and where can i get a convergence output for my tv ???
    Thanks
    Doug
  • Anonymous Oct 13, 2008
    I HAVE THE SAME PROBLEM,
    Scholar:
  • 146 Answers
The remote is not the problem. the convergence is the problem. You need to replaced the convergence amplifer output ic's. or take it to a repair shop.
Posted on Mar 15, 2008
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
Apex GB51HD09 convergence
Please have it taken care of ASAP. It definitely sounds like Cold Solder joints on the convergence IC's. Cheap repair now, if you stop playing it. Every-time the convergence goes out, the ic's struggle to bring it back in and can't and therefor over heat. so please have it taken care of Pronto. Apex used a Samsung chassis which was a good chassis in that PTV.
Aug 19, 2009 | Apex Digital GB51HD09 51" Rear Projection...
I see the convergence option in menu but nothing changed
Since you have the convergence options in your menu i would figure that you do not have the common fl231 fuse problem....Now is any part of the picture good. is the picture a bow tie. if you go into red and blue manual option will the crosshairs move up and down and left and right. If you have the bowtie or push in fromtop and bottoml then the likely problem is what is call the convergence power board. if you do have some control over the crosshairs then it may be the convergence amp board. convergence is controled by three diffrent cuicit boards. if you have to replace these boards it may just may need someone like a tech to do a serivce convergence.
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
After the thunderstorm...
these are amplifer ic's that drive your convergence yokes. this is not something that a consumer can do.
Mar 15, 2008 | Apex Digital GB51HD09 51" Rear Projection...
No crosshair on manuel convergence
It may be the fluid in the CRT or convergence chips are bad.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2008 | Philips 51PP9100D 51 in. Television
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Convergence?
You have a fault on the convergence module. Might be an STK, might be something else but repair is definitely warranted.
Jun 07, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Tried convergance, but would work
probably need to replace the convergence ICs inside the TV. The Ic is about 2" x 3" and mounted on large aluminum heatsink. Usually 2 or 3 (depends on model)
Jan 20, 2007 | Mitsubishi VS-55609 55" Rear Projection...
Apex Digital GB51HD09 51" Rear Projection Television Logo
230 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
