Installed new washer folowing directions including tilting to set rear leg adjustment and checked level with leveler. Did minor jolting test with my hands to see if washer was steady. seemed very steady. Used for first time. When wash finished, front of washer had moved 4-4.5 inches to one side, hitting against soapstone sink. I figure sink was the only thing stopping it from moving further. What to do to prevent washing from "travelling".
  • 770 Answers
Depends on the model did you remove the shipping blocks or straps?? Plz post model number
Posted on Mar 15, 2008
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
Tip
Maintain ur washing machine
<p><b><span><span>Tricks to Keep Your <a href="http://www.repairclinic.com/referral.asp?R=1230&P=53&Ref=1014%20">Washing Machine</a> Maintained</span></span></b><br /> <p> <b>Water-fill hoses </b><br /> <p>Over time, the rubber water hoses that came with your new washing machine may leak or burst. It's a good preventive maintenance practice to check these hoses from time to time for any sign of wear or weakness. Often there's a small blister in the rubber of the hose, which could rupture. Most manufacturers recommend replacing the hoses every 5 years. An alternative is to replace the rubber hoses with high quality <a href="http://www.repairclinic.com/referral.asp?R=1230&P=77&RccPartID=1012448&Acc=1&%20Ref=1014%20%20">stainless steel fill hoses</a>, which are more rugged. <br /> <p><b>Leveling </b><br /> If your washing machine is not level, it can vibrate strongly during the spin cycle. If your washing machine is not perfectly level--with all four legs touching the floor--it can bang and rock back and forth, and even begin to "walk" across the room. This isn't good for the machine and may damage anything near the machine. Use the adjustable front and/or back leveling legs on the washer to adjust the machine to the proper height, then tighten the lock nut up against the body of the machine to keep the leg from rotating.<br /> <ul> <ul> <li>Most machines, however, have "self-adjusting" rear legs. You set these legs by tilting the entire machine forward onto its front legs (with the rear legs 3 to 4 inches off the floor) and then setting the machine back down. The legs should adjust automatically. If they don't, you may need to tilt the machine forward and rap on the rear legs with the handle of a hammer to loosen them--a procedure that's easier to accomplish with a helper. </li></ul></ul> <p><b>Surface cleaning </b><br /> Your washer has either a painted steel or porcelain-coated steel cabinet. It's perfectly safe to use a little dish detergent and a damp rag to clean all of its surfaces. If the surface is porcelain, you can even use a little non-abrasive cleanser for stubborn stains. <br />
on Jan 27, 2011 | Washing Machines
I have a Maytag Model # LA806-02, which dances across the flor when in the spin mode. Tighting the three centering spring has helped very little.
If your Maytag is dancing across the floor the most common problem is the leveling. If one or more of the feet are not level it ill wobble and walk around the floor. When you level the machine on the top both directions make sure the set nut is tightened so you will not have to retighten it again later.
May 08, 2011 | Maytag Washing Machines
Washer is out of balance in the dpin cycle since we installed a new floating floor in our laundry room. Have tried rubber feet for levelers and sticky pads to floor, nothing seems to help.
So, is the machine level and STABLE? The final step is to tilt the machine forward on to the two front feet. This allows the rear, SELF LEVELING legs to reset. Then set the machine back on all four feet.
Sometimes the real feet get jambed and will not release unless you pry them loose. In extreme cases the rear feet damage the plastic holder that they are in...
BUT, the tilt foreward and set back on rear legs works most every time.
May 01, 2011 | Washing Machines
Why does the tub hit the liner on my whirlpool washer?
Sounds like it may be off balance. First tilt the rear of the washer onto the front legs a few inches (make sure the rear legs come off the ground if even just a few inches.) and then let the washer drop back on its rear legs. This is an auto level feature on many washers. Now use a level on the outer edges on the top of the washer and make sure it is level. Adjust the front feet as necessary. Also make sure you are evenly loading your washer so the tub does not "swing" into the side.
Mar 17, 2011 | Whirlpool Washing Machines
Leveling legs during set-up
If you just purchased this wahser and had it delivered, make sure you remove the shipping bolt(s). There is a large pin inseted in the back of the washer that must be removed BEFORE you attempt to use it. All the balancing in the world will not prevent it from vibrating if the pin is still installed.
If the shipping bolt has been removed, the following link can give you some added pointers on how to level your washer:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
Whirlpool manufactured top loaders have an auto-leveling mechanism on the rear feet that needs to be adjusted first. Once the rear feet are set, adjust the front to match the back, by turning the front feet. Make sure you check the level side-to-side as well. DO NOT place the level on the washer lid when checking the level as the washer lid is usually bowed and will not give you an accurate reading. Once you have the washer leveled, you can place nuts on the front feet to lock them in place and prevent them from becoming unleveled. The rear mechanism should be rechecked periodically by following the procedures in the link I provided.
If you have any questions, please post back and let me know. I hope this helps you.
May 10, 2010 | Roper RAS8445KQ Top Load Washer
Spin cycle
Make sure the shipping pins have been removed. They're usually attached to yellow strap at the rear of the machine (sometimes people just cut off the strap so look underneath as well to make sure it has been removed). Looking at the inside, the washer drum should move freely from front to back and side to side.
Next is leveling. This is sometimes tricky in that it really has nothing to do putting a level on the machine unless your floor is uneven and adjustments need to be made to the front legs. As long as it looks fairly straight to the eye, level the machine by opening the lid, putting your foot in front of machine and holding the inside of the cabinet. Tilt the machine toward you and lift the rear of the machine about 2-3 inches (you should hear the legs drop). Set it back down. It should now be leveled since the rear legs are self leveling. Try rocking the machine from the top in a diagonal motion and ensure the weight is evenly distributed on all 4 legs.
If these things have been checked and it's still "walking" make sure the load inside the washer is not off balance.
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Spins off balance
Hello kel_lyn_eve,
Because your washing machine is so heavy, when it's not level, it can vibrate strongly during the spin cycle. If your washing machine is not perfectly level--with all four legs touching the floor--it can bang and rock back and forth, and even begin to "walk" across the room. This isn't good for the machine and may damage anything near the machine.
Your washing machine has adjustable, front leveling legs with a lock nut. You adjust the leg to the proper height, then tighten the lock nut up against the body of the machine to keep the leg from rotating.
Some machines have adjustable leveling legs in the rear also, and you can adjust them in the same way. Keep the machine as close to the floor as possible--the lower it is, the less likely it is to vibrate.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 12, 2008 | Washing Machines
BACK LEG LEVELING ARM
The back legs are usually not adjustable. Adjust the front legs & lock them with the lock nuts, at the lowest level, that is the machine tilts towards the front. Adjust further if there is any shake when you try with your hands.
You could also check to see if any springs or shocks have become loose. Refer manual.
Mar 30, 2008 | Washing Machines
Leveling a washer tub how to do so
first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
